查看: 3259|回复: 7
[源码] 按通配符选文字
发表于 2015-5-10 21:24:24 | 显示全部楼层 |阅读模式
通配符参考wmatch说明,方便根据内容来快速筛选文字对象。
Wild-card characters
Character
Definition
# (pound)
Matches any single numeric digit.
@ (at)
Matches any single alphabetic character.
. (period)
Matches any single nonalphanumeric character.
* (asterisk)
Matches any character sequence, including an empty one, and it can be used anywhere in the search pattern: at the beginning, middle, or end.
? (question mark)
Matches any single character.
~ (tilde)
If it is the first character in the pattern, it matches anything except the pattern.
Matches any one of the characters enclosed.
Matches any single character not enclosed.
- (hyphen)
Used inside brackets to specify a range for a single character.
, (comma)
Separates two patterns.
` (reverse quote)
Escapes special characters (reads next character literally).
  1. (defun c:qs (/ rt ss)
  2.   (if (null *qs-text-pattern*)
  3.     (setq *qs-text-pattern* "C#,M#,FM#")
  4.   )
  5.   (if (/= ""
  6.           (setq rt (getstring (strcat "\n输入文字内容通配符 <\"" *qs-text-pattern* "\">: ")))
  7.       )
  8.     (setq *qs-text-pattern* rt)
  9.   )
  10.   (if (and
  11.         (setq ss (ssget (list '(0 . "*TEXT") (cons 1 *qs-text-pattern*))))
  12.         (= 0 (getvar "CMDACTIVE"))
  13.       )
  14.     (progn
  15.       (sssetfirst nil ss)
  16.       (princ (strcat "\n选择了 " (itoa (sslength ss)) " 个对象。"))
  17.     )
  18.   )
  19.   (princ)
  20. )
参与人数 2明经币 +2 收起 理由
USER2128 + 1 赞一个!
Gu_xl + 1 赞一个!
本帖被以下淘专辑推荐:
发表于 2015-5-10 23:39:30 | 显示全部楼层
一直不知道LISP的通配符规定,谢谢
发表于 2015-5-12 13:48:57 | 显示全部楼层
错误: 输入的字符串有缺陷
 楼主| 发表于 2015-5-12 14:10:27 | 显示全部楼层
机械工程师 发表于 2015-5-12 13:48
错误: 输入的字符串有缺陷
请提供出现此错误时所使用的通配符,以帮助分析原因。
发表于 2015-5-13 15:24:18 | 显示全部楼层
可参考小菜的选择易源码
发表于 2015-5-14 08:33:18 | 显示全部楼层
由于保存代码时按utf保存了,导致加载此文件会出现
错误: 输入的字符串有缺陷
的提示,
用ansi保存就没问题了。
详见下图。
发表于 2019-10-30 00:15:01 来自手机 | 显示全部楼层
谢谢分享,学习了
发表于 2019-11-6 12:01:47 | 显示全部楼层
感谢大神的分享!谢谢!
GMT+8, 2025-10-21 05:08 , Processed in 0.182225 second(s), 30 queries , Gzip On.
