查看: 1215|回复: 1
[提问] 请高手帮忙完美一下这个字对齐线么?当线竖直时候提示除数为0
发表于 2015-5-16 08:46:39 | 显示全部楼层 |阅读模式
有人帮忙完美一下这个字对齐线么?我一直用这个程序,但是有个小bug,当线竖直时候提示除数为0,其他的情况都很好用的,先谢谢了!
;---------- 字对齐线 开始(程序2)
;;  通用grread定义
(defun ZML-GRREAD(LST / TEST TMP MODE VAL TMP2)
    (setq TEST t)
    (while TEST
  (setq TMP  (grread 2)
        MODE (car TMP)
        VAL  (cadr TMP)
  (cond ((= MODE 2)
         (if (and  (setq TMP2 (assoc MODE LST))
      (setq TMP2 (cdr TMP2))
      (setq TMP2 (assoc VAL TMP2))
       (eval (cons 'progn (cdr TMP2)))
        ((setq TMP2 (assoc MODE LST))
        (t (princ TMP))
;;;文字随线(角度随线的)
(vl-load-com)
(defun C:xz(/ tt-01 tt-02 LST)
    ;;功能:计算计算距给定点位最近的线上点 和 线上点的前进方位角
    ;;参数:EN_LINE -----线的图元名称
    ;;           PT -----给定点位
    ;;返回:距点最近的线上点 和 线上点的方位角
    (defun TT-01 (EN_LINE PT / OBJ PT1 LST ANG)
  ;;将图元名转换为 VLA对象
  (setq OBJ (vlax-ename->vla-object EN_LINE))
  ;;距pt最近的曲线上的点pt1
  (setq PT1 (vlax-curve-getclosestpointto OBJ PT))
  ;;pt1点的切线方向矢量
  (setq LST (vlax-curve-getfirstderiv
          OBJ
          (vlax-curve-getparamatpoint
        OBJ
        PT1
  ;;计算切线方位角
  (setq ANG (atan (/ (cadr LST) (car LST))))
  ;;返回
  (list PT1 ANG)
    ;;功能:设置文字对象位置及角度
    (defun TT-02 (EN_TEXT PT ANG / ENT)
  (setq ENT (entget EN_TEXT))
  (setq ENT (subst (cons 10 PT) (assoc 10 ENT) ENT)
        ENT (subst (cons 11 PT) (assoc 11 ENT) ENT)
        ENT (subst (cons 50 ANG) (assoc 50 ENT) ENT)
  (entmod ENT)
    (if  (and
      (setq SS (entsel "\n点取线: "))
      (setq EN_LINE (car SS))
      (setq ENT_LINE (entget EN_LINE))
      (wcmatch (cdr (assoc 0 ENT_LINE))
         "LINE,ARC,LWPOLYLINE,SPLINE"
      (setq SS (entsel "\n点取文字: "))
      (setq EN_TEXT (car SS))
      (setq ENT_TEXT (entget EN_TEXT))
      (wcmatch (cdr (assoc 0 ENT_TEXT)) "TEXT,MTEXT")
      (setq LST
         (list '(5
           (setq
            TMP
            (TT-01 EN_LINE VAL)
            PT1
            (car TMP)
            ANG
            (cadr TMP)
           (TT-02 EN_TEXT VAL ANG)
             (vlax-get-property (vlax-ename->vla-object EN_text) 'InsertionPoint )
           (redraw)
           (grdraw VAL PT1 1)
         ;;左击
          (3
           (redraw)
           (setq TEST NIL)
         '(25
           (redraw)
           (setq TEST NIL)
         '(11
           (redraw)
           (setq TEST NIL)
      (ZML-GRREAD LST)
;---------- 字对齐线 结束
发表于 2021-12-27 10:46:49 | 显示全部楼层
功能挺好的
GMT+8, 2025-5-16 08:56 , Processed in 0.170719 second(s), 29 queries , Gzip On.
