查看: 17552|回复: 119
[源码] 斜坡线绘制
发表于 2015-5-16 09:58:11 | 显示全部楼层 |阅读模式
看见有人求画斜坡线的, 非此专业,不懂,但记得曾经收集过此类程序
因为分享出来,仅此而已,不懂勿问,不喜勿喷。
  1. (defun C:SLOPE-LINE (/ Talud_boven  Talud_onder afstand afstand_totaal count p1 p2 kleur)
  2.   (defun IS-ON-PL? (ENAME PKT /)
  3.     (vl-catch-all-apply
  4.       'vlax-curve-getdistatpoint
  5.       (list
  6.         ENAME
  7.         PKT
  8.         ) ;_ end of list
  9.       ) ;_ end of vlax-curve-getDistAtPoint
  10.     PKT
  11.     ) ;_ end defun
  12. (vl-load-com)
  13.   (if (and (setq Talud_boven (car (entsel "\nSelect Top slope: ")))
  14.            (setq Talud_onder (car (entsel "\nSelect Bottom slope: ")))
  15.            (setq afstand (getint "\nLine slope distance:"))
  16.            (setq kleur (acad_colordlg 8))
  17.            ) ;_ end of and
  18.
  19.     (progn
  20.       (setq afstand_totaal 0)
  21.       (setq count 0)
  22.       (setq p1 (vlax-curve-getStartPoint
  23.                  (vlax-ename->vla-object Talud_boven)
  24.                  ) ;_ end of vlax-curve-getStartPoint
  25.             ) ;_ end of setq
  26.       (while p1
  27.         (if (equal (/ count 2.0) (fix (/ count 2.0)) 0.001)
  28.           (setq p2
  29.                  (vlax-curve-getClosestPointTo
  30.                    (vlax-ename->vla-object Talud_onder)
  31.                    p1
  32.                    ) ;_ end of vlax-curve-getClosestPointTo
  33.                 ) ;_ end of setq
  34.           (setq
  35.             p2 (MAPCAR '(LAMBDA (x) (/ x 2))
  36.                        (MAPCAR '+
  37.                                p1
  38.                                (vlax-curve-getClosestPointTo
  39.                                  (vlax-ename->vla-object Talud_onder)
  40.                                  p1
  41.                                  ) ;_ end of vlax-curve-getClosestPointTo
  42.                                ) ;_ end of MAPCAR
  43.                        ) ;_ end of MAPCAR
  44.             ) ;_ end of setq
  45.           ) ;_ end of if
  46.         (entmake
  47.           (list '(0 . "LINE")
  48.                 (cons 10 p1)
  49.                 (cons 11 p2)
  50.                 ;'(62 . 1) ; standaard kleur
  51.                 (cons 62 kleur) ; kleur dia dialog instellen
  52.           ) ;_ end of list
  53.         ) ;_ end of entmake
  54.         (if
  55.           (setq p1 (IS-ON-PL?
  56.                      (vlax-ename->vla-object Talud_boven)
  57.                      (vlax-curve-getpointatdist
  58.                        (vlax-ename->vla-object Talud_boven)
  59.                        (setq afstand_totaal (+ afstand_totaal afstand))
  60.                        ) ;_ end of vlax-curve-getpointatdist
  61.                      ) ;_ end of IS-ON-PL?
  62.                 ) ;_ end of setq
  63.            p1
  64.            ) ;_ end of if
  65.         (setq count (1+ count))
  66.         ) ;_ end of while
  67.       ) ;_ end of progn
  68.     ) ;_ end of if
  69.   ) ;_ end of defun
参与人数 4明经币 +3 金钱 +40 收起 理由
stoneball + 1 很给力!
zf9568 + 1 + 20 很给力!
lawrence + 20 很给力!
zcmfk + 1 很给力!
本帖被以下淘专辑推荐:
发表于 2019-7-26 14:49:46 | 显示全部楼层
学习学习!多谢楼主!!
发表于 2015-5-16 10:24:02 | 显示全部楼层
看似很神奇
发表于 2015-5-16 10:29:05 | 显示全部楼层
感谢 lucas_3333 分享程序!
 楼主| 发表于 2015-5-16 10:40:05 | 显示全部楼层
yoyoho 发表于 2015-5-16 10:29
感谢 lucas_3333 分享程序!
只要有源码的地方就有你的身影,不论是哪行哪业
你是专业收集源码的吗?
为何不分享一些出来? 箱子沉了,背着累!
发表于 2015-5-16 10:48:51 | 显示全部楼层
好东西哦,回复学习学习
发表于 2015-5-16 12:09:50 | 显示全部楼层
这个是示坡线
发表于 2015-5-16 13:56:42 | 显示全部楼层
斜坡线绘制....
发表于 2015-5-16 14:25:18 | 显示全部楼层
好像见过,感谢 lucas_3333 分享
发表于 2015-5-16 16:15:24 | 显示全部楼层
谢谢分享程序。
发表于 2015-5-16 17:55:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2026-1-19 04:06 , Processed in 0.214317 second(s), 32 queries , Gzip On.
