查看: 1192|回复: 5
[提问] 表 排序 分级
发表于 2015-5-17 13:43:02 | 显示全部楼层 |阅读模式
("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")
("11" "12" "13" "14" "15" "16") ("12" "13") ("12" "13" "14" "15""16")
("16") ("2") ("2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")
("2" "3") ("4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")
("4" "5") ("5") ("6") ("6" "7" "8" "9" "10") ("7" "8") ("8" "12") ("9")("1")
("14") ("14" "15") ("10") ("11")
表比较得到
("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")  1
("1")  2
("2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")  2
("2" "3")  3
("4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16") 3
("8" "12") 4   ("2")  4   ("4" "5")  4  ("6" "7" "8" "9" "10") 4
("11" "12" "13" "14" "15" "16")  4
("5") 5   ("6")  5  ("10")  5    ("9") 5   ("11")  5
("7" "8")  5  ("12" "13" "14" "15""16")  5
("16")  6  ("12" "13") 6    ("14" "15")  6  ("14") 7
数字表示级别
 楼主| 发表于 2015-5-17 15:54:36 | 显示全部楼层
(defun xxj ( / )
(setq tth (xxh) tti (xxi) ttc (xxc)oba '()obb '())
(setq ls (del-same tth)  lt (del-same tti) lc (del-same ttc) i 0 xs'())
(repeat (length ls)
  (setq aa (nth i ls))
  (setq bb (cdr aa)cc (remove bb lt) k 0)
  (if (=(length lc)(car aa))
   (setq oa (list (cons 1 bb)) oba (append oa oba))
  (while (< k (length cc))
   (setq dd (nth k cc))
   (if (<(length bb)(length dd))
     (setq ob'()oc'()od'()oe'())
     (foreach x  bb  (setq dd (vl-remove x dd)))
     (if dd
       (setq ob (list(cons((length dd) bb))) oc (append ob oc) od (l_ssort oc 0 '>))
     (if od (setq oe od)(setq oe oc))
   (setq k (+ k 1))
  (setq oba (append oe oba))
  (setq i (+ i 1))
oba
)  不行
发表于 2015-5-28 16:11:18 | 显示全部楼层
  1. (defun xxj(a)
  2.   (vl-sort(mapcar'(lambda(x)(list x(length(vl-remove'nil(mapcar'(lambda(y)(apply'and(mapcar'(lambda(z)(member z y))x)))a)))))a)'(lambda(x y)(<(last x)(last y))))
  3.   )
(xxj'(("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16")
("14") ("14" "15") ("10") ("11")))
((("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16") 1) (("2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16") 2) (("1") 2) (("2" "3") 3) (("4" "5" "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16") 3) (("11" "12" "13" "14" "15" "16") 4) (("2") 4) (("4" "5") 4) (("6" "7" "8" "9" "10") 4) (("8" "12") 4) (("12" "13" "14" "15" "16") 5) (("5") 5) (("6") 5) (("7" "8") 5) (("9") 5) (("10") 5) (("11") 5) (("12" "13") 6) (("16") 6) (("14" "15") 6) (("14") 7))
 楼主| 发表于 2015-5-28 20:15:08 | 显示全部楼层
这种情况下不对
 楼主| 发表于 2015-5-28 20:16:19 | 显示全部楼层
("11" "12" "13" ...
还有问题 请帮我看一下啊
 楼主| 发表于 2016-9-30 22:48:22 | 显示全部楼层
已经解决1121312312
GMT+8, 2025-5-20 04:46 , Processed in 0.149246 second(s), 27 queries , Gzip On.
