查看: 15994|回复: 91
[源码] 切换视图
发表于 2015-5-24 11:23:58 | 显示全部楼层 |阅读模式
请选择视图方向:
俯视图(A)
仰视图(S)
左视图(D)
右视图(F)
前视图(G)
后视图(H)
东南等轴测(1)
西南等轴测(2)
东北等轴测(3)
西北等轴测(4)
绕X轴旋转(5)
绕Y轴旋转(6)
绕Z轴旋转(7)
初始视图(O)
  1. ;;;*****切换视图 程序开始*****
  2. (defun c:t1 ()
  3.   (setvar "cmdecho" 0)
  4.   (setvar "expert" 2)
  5.   (initget "A S D F G H 1 2 3 4 5 6 7 O")
  6.   (if (not (setq kw
  7.                   (getkword
  8.                     "\n请选择视图方向:[俯视图(A)/仰视图(S)/左视图(D)/
  9. 右视图(F)/前视图(G)/后视图(H)/东南等轴测(1)/西南等轴测(2)/东北等轴测
  10. (3)/西北等轴测(4)/绕X轴旋转(5)/绕Y轴旋转(6)/绕Z轴旋转(7)/初始视图(O)]
  11. <A>"                  )
  12.            )
  13.       )
  14.     (setq kw "A")
  15.   )
  16.   (cond
  17.     ((= kw "A")
  18.      (command "_view" "top")
  19.      (princ "\n当前视图为:俯视")
  20.     )                                        ;俯视
  21.     ((= kw "S")
  22.      (command "_view" "bottom")
  23.      (princ "\n当前视图为:仰视")
  24.     )                                        ;仰视
  25.     ((= kw "D")
  26.      (command "_view" "left")
  27.      (princ "\n当前视图为:左视")
  28.     )                                        ;左视
  29.     ((= kw "F")
  30.      (command "_view" "right")
  31.      (princ "\n当前视图为:右视")
  32.     )                                        ;右视
  33.     ((= kw "G")
  34.      (command "_view" "front")
  35.      (princ "\n当前视图为:前视")
  36.     )                                        ;前视
  37.     ((= kw "H")
  38.      (command "_view" "back")
  39.      (princ "\n当前视图为:后视")
  40.     )                                        ;后视
  41.     ((= kw "1")
  42.      (command "_view" "seiso")
  43.      (princ "\n当前视图为:东南等轴测")
  44.     )                                        ;东南等轴测
  45.     ((= kw "2")
  46.      (command "_view" "swiso")
  47.      (princ "\n当前视图为:西南等轴测")
  48.     )                                        ;西南等轴测
  49.     ((= kw "3")
  50.      (command "_view" "neiso")
  51.      (princ "\n当前视图为:东北等轴测")
  52.     )                                        ;东北等轴测
  53.     ((= kw "4")
  54.      (command "_view" "nwiso")
  55.      (princ "\n当前视图为:西北等轴测")
  56.     )                                        ;西北等轴测
  57.     ((= kw "5")
  58.      (if (not (setq ang (getreal "请输入要绕X轴旋转的角度:<90.0>")))
  59.        (setq ang 90.0)
  60.      )
  61.      (command "_UCS" "_X" ang)
  62.     )                                        ;绕X轴旋转
  63.     ((= kw "6")
  64.      (if (not (setq ang (getreal "请输入要绕Y轴旋转的角度:<90.0>")))
  65.        (setq ang 90.0)
  66.      )
  67.      (command "_UCS" "_Y" ang)
  68.     )                                        ;绕Y轴旋转
  69.     ((= kw "7")
  70.      (if (not (setq ang (getreal "请输入要绕Z轴旋转的角度:<90.0>")))
  71.        (setq ang 90.0)
  72.      )
  73.      (command "_UCS" "_Z" ang)
  74.     )                                        ;绕Z轴旋转
  75.     ((= kw "O")
  76.      (command "_view" "top")
  77.      (command "_UCS" "_W")
  78.      (princ "\n★提示:设置后的视图为:俯视、坐标系为:世界坐标系!\n")))(princ))
  79. ;;;想继续看吗?
;;;*****切换视图 程序结束*****
或者直接下载WDY工具
里面有直接集成的:http://bbs.mjtd.com/thread-108389-1-1.html
发表于 2022-2-11 13:05:21 | 显示全部楼层
绕x,y,z轴旋转,只是坐标轴转了,但是视图没转呀?请问如何让视图也跟着转
发表于 2021-11-22 07:40:51 | 显示全部楼层
好東西就是要頂一下,謝謝
发表于 2021-11-21 23:04:44 | 显示全部楼层
好东西就是要顶一下,谢谢
发表于 2025-1-15 17:34:59 | 显示全部楼层
好东西就是要顶一下
发表于 2016-7-31 01:33:55 | 显示全部楼层
HAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2016-7-28 22:38:16 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2016-7-4 00:17:29 | 显示全部楼层
好东西就是要顶一下,谢谢
发表于 2016-7-1 14:52:30 | 显示全部楼层
学习学习学习学习想
发表于 2016-7-1 11:32:16 | 显示全部楼层
看看楼主写了啥
GMT+8, 2025-5-22 22:15 , Processed in 0.238997 second(s), 34 queries , Gzip On.
