查看: 2237|回复: 7
重新上传(一个AutoCAD2000开发小例子)
发表于 2003-10-22 09:41:00 | 显示全部楼层 |阅读模式
(一个AutoCAD2000开发小例子) 重新上传
  解决了meflying提出的版本冲突问题,在创建AutoCAD实例对象时应加版本号:
      Public AcadApp As AcadApplication
      Set AcadApp = CreateObject("Autocad.application.15")
  谢谢meflying版主和mccad.
                                  Oct 22, 2003
发表于 2003-10-22 09:51:00 | 显示全部楼层
什么意思,我装了2004和2000,它告诉我说没有装2000,却给我运行了两个2004的属性框,莫名其妙:
发表于 2003-10-22 10:55:00 | 显示全部楼层
高手!!!
发表于 2003-10-22 12:15:00 | 显示全部楼层
请问王版主:
怎样把图标.bmp建立成.dll文件,并运用这个.dll文件???
帮帮忙……
 楼主| 发表于 2003-10-22 12:24:00 | 显示全部楼层
启动一下AutoCAD 2000后关闭,在执行acad_demo.exe,
要么把acad_demo.exe重新编译一下试试,重新引用一下AutoCAD 2000的类型库.
好象安装了多个版本,用VB激活AutoCAD时, 有时不能启动正确版本...
 楼主| 发表于 2003-10-22 12:34:00 | 显示全部楼层
按以下步骤(转载), 把编译的dll和你的mnu文件放在同一路径下,名称相同(不知是否一定).
If you have several bitmaps associated with a menu, you can save disk space and avoid those annoying smiley faces by compiling your graphics into a dll. Here's how:
1.  Start a new ActiveX DLL project
2.  In the Project Explorer window, right click "roject1" and select "roject1 Properties"
3.  In the Project Name edit box, enter the name of your mnu file. Press OK
4.  Select Add-Ins | Add-In Manager
5.  Select the VB6 Resource Editor
6.  In the Load Behavior section (lower right), select "Loaded". Press OK
7.  You now have a new toolbar button (the green cubes with a hand on them). Press it
8.  Use the "Add Bitmap" button to add your bitmaps (the cactus)
9.  Be sure to rename them, then save and close.
10. Compile the DLL and place it the same folder as your menu
Remember, small bitmaps are 16x15. No point in making large icons since AutoCAD will only scale the small ones. To use the bitmaps, simply call them by name in your button defintions:
[_Button("Hide all", "HIDEALL", "HIDEALL")]^C^C<your macro here>
Also, be aware that Win9x  limits the number of bitmaps you can store in a dll. NT does not suffer from this limitation.
资源:
二个联接网址: http://www.afralisp.com/links.htm
                    http://code.acadx.com/
                    的Code专区How to do...? 的 Visual Basic可以找到.
发表于 2003-10-22 14:00:00 | 显示全部楼层
谢谢!!!
 楼主| 发表于 2003-10-22 21:05:00 | 显示全部楼层
抱歉,我在创建AutoCAD实例时没有加版本号(CreateObject函数).刚问过mccad.
GMT+8, 2025-5-15 11:00 , Processed in 0.176125 second(s), 27 queries , Gzip On.
