查看: 1854|回复: 2
这个话题该在这里吧!用API函数调用FORTRAN程序在VB里输入和显示数据
发表于 2003-10-22 19:47:00 | 显示全部楼层 |阅读模式
这是FORTRAN程序:
  program sort
      dimension arr(10)
      integer n
      nupper=10
      open(1,file='e:\beforesort.dat',status='old')
      do 10 n=1,nupper
      read(1,*) arr(n)
  10  continue
      open(2,file='e:\aftersort.dat')
      do 40 n=1,nupper
      write(2,100)'第',n,'数',arr(n)
      write(*,100)'第',n,'个数',arr(n)
   40 continue
  100 format(1x,a5,i2,a5,1x,f8.3)
      close(1)
      close(2)
      end
在VB里用API函数调用FORTRAN
Private Declare Function WaitForSingleObject Lib "kernel32" (ByVal hHandle As Long, ByVal dwMilliseconds As Long) As Long
Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
Private Declare Function OpenProcess Lib "kernel32" (ByVal dwDesiredAccess As Long, ByVal bInheritHandle As Long, ByVal dwProcessId As Long) As Long
Private Const infinite = -1&
Private Const synchroniz = &H100000
Private Sub Command1_Click()
Dim itask As Long, ret As Long, phandle As Long
filename1 = "e:\beforesort.dat"
filename2 = "e:\aftersort.dat"
Open filename1 For Output As #1
  For i = 0 To 9
   Print #1, Val(Text1(i).Text)
  Next
Close #1
itask = Shell("e:\sort.exe", vbHide)
phandle = OpenProcess(synchronize, False, itask)
ret = WaitForSingleObject(phandle, infinite)
ret = CloseHandle(phandle)
RichTextBox1.LoadFile filename2, rtfText
End Sub
程序执行时出现死机现象,怎么回事?
发表于 2003-10-22 20:08:00 | 显示全部楼层
你已经在FORTRAN中生成了文本文件,其实在VB中显示文本文件不用那么复杂吧
 楼主| 发表于 2003-10-22 20:55:00 | 显示全部楼层
问题已经解决!谢谢明总
GMT+8, 2025-5-10 23:12 , Processed in 0.159747 second(s), 23 queries , Gzip On.
