查看: 1469|回复: 2
lilin,帮我解答一下这个问题,好吗?
发表于 2003-10-25 22:06:00 | 显示全部楼层 |阅读模式
lilin,网上邮箱打不开!(arx2000)
通过检索“printdxf”得到一份帮助代码,但我在调试时报错:
An ObjectARX application could retrieve and print the definition data for an entity by using the following two functions. (The printdxf() function does not handle extended data.)
void getlast()
    struct resbuf *ebuf, *eb;
    ads_name ent1;
    acdbEntLast(ent1);
    ebuf = acdbEntGet(ent1);
    eb = ebuf;
    acutPrintf("\nResults of entgetting last entity\n");
// Print items in the list.
    for (eb = ebuf; eb != NULL; eb = eb->rbnext)
        printdxf(eb);          //printdxf此函数没有类型定义????报错一
// Release the acdbEntGet() list.
    acutRelRb(ebuf);
int printdxf(eb)
struct resbuf *eb;      //这句就更不清楚是怎么回事了?又是int,又是struct
                               //而且一个指针*eb没有赋值
    int rt;
    if (eb == NULL)
        return RTNONE;
    if ((eb->restype >= 0) && (eb->restype <= 9))
        rt = RTSTR ;
    else if ((eb->restype >= 10) && (eb->restype <= 19))
        rt = RT3DPOINT;
    else if ((eb->restype >= 38) && (eb->restype <= 59))
        rt = RTREAL ;
    else if ((eb->restype >= 60) && (eb->restype <= 79))
        rt = RTSHORT ;
    else if ((eb->restype >= 210) && (eb->restype <= 239))
        rt = RT3DPOINT ;
    else if (eb->restype < 0)
// Entity name (or other sentinel)
        rt = eb->restype;
    else
        rt = RTNONE;
    switch (rt) {
    case RTSHORT:
        acutPrintf("(%d . %d)\n", eb->restype,
            eb->resval.rint);
        break;
    case RTREAL:
        acutPrintf("(%d . %0.3f)\n", eb->restype,
            eb->resval.rreal);
        break;
    case RTSTR:
        acutPrintf("(%d . \"%s\")\n", eb->restype,
            eb->resval.rstring);
        break;
    case RT3DPOINT:
        acutPrintf("(%d . %0.3f %0.3f %0.3f)\n",
            eb->restype,
            eb->resval.rpoint[X], eb->resval.rpoint[Y],
            eb->resval.rpoint[Z]);
        break;
    case RTNONE:
        acutPrintf("(%d . Unknown type)\n", eb->restype);
        break;
    case -1:
    case -2:
// First block entity
        acutPrintf("(%d . <Entity name: %8lx>)\n",
            eb->restype, eb->resval.rlname[0]);
    return eb->restype;
我傻了,能帮我解答一下吗?我想提取形位公差的数据信息,还有其他样例吗?
形位公差的restype =1
发表于 2003-10-27 10:14:00 | 显示全部楼层
int printdxf(eb)
struct resbuf *eb
这是一种老式的C风格.
建议用以下, int printdxf(struct resbuf *eb) 代替
 楼主| 发表于 2003-10-27 21:12:00 | 显示全部楼层
谢谢斑竹,
我今天调试,结果出来了!将形位公差图元中所有的信息都提取出来了
不错不错!happy...........................
GMT+8, 2025-4-5 23:52 , Processed in 0.257382 second(s), 23 queries , Gzip On.
