查看: 1562|回复: 2
大虾们,这个程序怎么写!
发表于 2003-10-29 12:39:00 | 显示全部楼层 |阅读模式
这条封闭多段线如何才能画出来?
请参看HELP.DWG
  1. 程序代码内容
复制代码
(setq ag 0);;;原始角
(setq WE (+ ag pi));;;西
(setq NO (+ ag (/ pi 2)));;;北
(setq SO (+ WE (/ pi 2)));;;南
(SETQ EA AG);;;东
(SETQ WN (+ AG (* PI 0.75)));;;西北
(SETQ EN (+ AG (* PI 0.25)));;;东北
(SETQ WS (+ AG (* PI 1.25)));;;西南
(SETQ ES (+ AG (* PI 1.75)));;;南
(defun draw_cir_odd(num h)
  (setq laya(+ 1 laya))
  (setq p10 (polar p0 no h))
  (command "circle" p10 hrgri)
  (repeat (/ num 2)
    (setq p10 (polar p10 0 s))
    (if (= laya 1)
      (setq pp1 p10)
    (if (= laya lays)
      (setq pp2 p10)
  (repeat (/ num 2)
    (setq p10 (polar p10 pi s))
    (if (= laya 1)
      (setq pp4 p10)
    (if (= laya lays)
      (setq pp3 p10)
(defun draw_cir_even(num h)
  (setq p10 (polar p10 pi (/ s 2.0)))
  (repeat (/ num 2)
    (if (= laya 1)
      (setq pp1 p10)
    (if (= laya lays)
      (setq pp2 p10)
  (setq p10 (polar p10 0 (/ s 2.0)))
  (repeat (/ num 2)
    (if (= laya 1)
      (setq pp4 p10)
    (if (= laya lays)
      (setq pp3 p10)
 楼主| 发表于 2003-11-2 12:09:00 | 显示全部楼层
我是个新手
请大家帮帮忙
发表于 2003-11-3 07:56:00 | 显示全部楼层
先把你的程序中未知的變數弄好再說!
GMT+8, 2025-6-12 07:18 , Processed in 0.244258 second(s), 27 queries , Gzip On.
