查看: 1642|回复: 2
VBA中,如何炸开Mline
发表于 2003-10-31 11:22:00 | 显示全部楼层 |阅读模式
如何炸开Mlind 为 line
object.Explode  不支持呀
发表于 2003-11-1 10:05:00 | 显示全部楼层
确实如此,希望以的版本能提供这样的方法;
  1. Sub ExampleExplodeMline()
  2.     Dim ssetObj As AcadSelectionSet
  3.     Dim i As Integer
  4.     Dim explodedObjects As Variant
  5.
  6.     Dim OldCount As Long, NewCount As Long
  7.
  8.     Set ssetObj = ThisDrawing.PickfirstSelectionSet
  9.     ssetObj.Clear
  10.     ssetObj.SelectOnScreen
  11.     If ssetObj.Count <= 0 Then Exit Sub
  12.     On Error Resume Next
  13.     explodedObjects = ssetObj(0).Explode
  14.     If Err Then
  15.         Err.Clear
  16.         OldCount = ThisDrawing.ModelSpace.Count
  17.         Debug.Print "炸开前的实体:"
  18.         For i = 0 To ThisDrawing.ModelSpace.Count
  19.             Debug.Print i & ":" & ThisDrawing.ModelSpace(i).ObjectName
  20.         Next i
  21.         ThisDrawing.SendCommand "_explode (handent " & Chr(34) & ssetObj(0).Handle & Chr(34) & ") " & vbCr
  22.         If OldCount <> ThisDrawing.ModelSpace.Count Then
  23.             Debug.Print "被炸开形成的实体:"
  24.             For i = OldCount - 1 To ThisDrawing.ModelSpace.Count
  25.                 Debug.Print i & ":" & ThisDrawing.ModelSpace(i).ObjectName
  26.             Next i
  27.         End If
  28.         Debug.Print "炸开后的实体:"
  29.         For i = 0 To ThisDrawing.ModelSpace.Count
  30.             Debug.Print i & ":" & ThisDrawing.ModelSpace(i).ObjectName
  31.         Next i
  32.         Exit Sub
  33.     End If
  34.     On Error GoTo 0
  35.     ' Loop through the exploded objects
  36.
  37.     For i = 0 To UBound(explodedObjects)
  38.         explodedObjects(i).Update
  39.         MsgBox "Exploded Object " & i & ": " & explodedObjects(i).ObjectName, , "Explode Example"
  40.         explodedObjects(i).color = acByLayer
  41.         explodedObjects(i).Update
  42.     Next
  43.
  44. End Sub
发表于 2003-11-1 07:25:00 | 显示全部楼层
ActiveX(VBA)对多线的支持太少了,只能通过SendCommand方法来打散。
GMT+8, 2025-5-24 19:41 , Processed in 0.176290 second(s), 24 queries , Gzip On.
