查看: 3658|回复: 12
一个很郁闷的问题。关于求文本宽度的。
发表于 2003-10-31 14:28:00 | 显示全部楼层 |阅读模式
在对Text对象执行GetBoundingBox方法时,居然提示“Invalid extents"错误。什么意思呀?Text对象应该是可以使用GetBoundingBox方法的呀。请老大们指教。
发表于 2003-10-31 18:53:00 | 显示全部楼层
从错误的说明来看,应该跟图纸界限设置有关系吧,是否文本位于界限之外。
发表于 2003-10-31 23:47:00 | 显示全部楼层
把你的代码帖上来看看问题出在哪里!
 楼主| 发表于 2003-11-3 09:20:00 | 显示全部楼层
Dim strText As String
    Dim oEntity As AcadEntity
    Dim oText As AcadText
    Dim bFound As Boolean
    Dim typeFace As String
    Dim Bold As Boolean
    Dim Italic As Boolean
    Dim charSet As Long
    Dim PitchandFamily As Long
    Dim InsertPoint(2) As Double
    Dim height As Double
    strText = InputBox("请输入需要查找的文字!")
    bFound = False
    For Each oEntity In oDoc.ModelSpace
        If oEntity.ObjectName = "AcDbText" Then
            Set oText = oDoc.ModelSpace.Item(i)
            DoEvents
            If LCase(oText.TextString) = strText Then
                height = 1
                InsertPoint(0) = oText.InsertionPoint(0) + 5
                InsertPoint(1) = oText.InsertionPoint(1) - (height + 5)
                InsertPoint(2) = oText.InsertionPoint(2)
                oDoc.ActiveTextStyle.GetFont typeFace, Bold, Italic, charSet, PitchandFamily
                oDoc.ActiveTextStyle.SetFont "宋体", False, False, charSet, PitchandFamily
                Set oText = oDoc.ModelSpace.AddText("测试", InsertPoint, height)
                oText.Update
            End If
        End If
        DoEvents
        i = i + 1
    Next
    MsgBox "OK!"
发表于 2003-11-3 09:54:00 | 显示全部楼层
给你这段没有问题的。
Sub textfont()
Dim typeface As String
Dim textbold As Boolean
Dim textitalic As Boolean
Dim textcharset As Long
Dim textpfamily As Long
ThisDrawing.ActiveTextStyle.GetFont typeface, _
textbold, textitalic, textcharset, textpfamily
MsgBox "当前字体为:" & typeface
typeface = "隶书"
ThisDrawing.ActiveTextStyle.SetFont typeface, _
ThisDrawing.Regen acActiveViewport
Dim textobj As AcadText
Dim textstring As String
Dim textheight As Double
Dim inspoint(0 To 2) As Double
textstring = "关章洋"
inspoint(0) = 10
inspoint(1) = 10
inspoint(2) = 0
textheight = 5
Set textobj = ThisDrawing.ModelSpace.AddText(textstring, inspoint, textheight)
End Sub
 楼主| 发表于 2003-11-3 10:07:00 | 显示全部楼层
to gzy,to All:
     sorry,贴错了,这段代码没有问题。:)
 楼主| 发表于 2003-11-3 10:11:00 | 显示全部楼层
有问题的代码如下:
    Dim Bold As Boolean
    Dim charSet As Long
    Dim minPoint As Variant, maxpoint As Variant
    bFound = False
            DoEvents
                oText.GetBoundingBox minPoint, maxpoint
                height = 1
                InsertPoint(0) = maxPoint(0) + 5
                InsertPoint(1) = maxPoint(1) - (height + 5)
                InsertPoint(2) = maxPoint(2)
                Set oText = oDoc.ModelSpace.AddText("朱震宇", InsertPoint, height)
                oText.Update
            End If
        End If
        DoEvents
        i = i + 1
    Next
    MsgBox "OK!"
'关键是oText.GetBoundingBox minPoint, maxpoint这句话出错。
 楼主| 发表于 2003-11-3 10:12:00 | 显示全部楼层
其实我的要求很简单,要么能通过GetBoundingBox获取文本的相应坐标,要么能获取文本的宽度。哪位老大帮帮忙?
发表于 2003-11-3 11:21:00 | 显示全部楼层
你的程序我试过了,没有出现问题。能顺利通过调试。不管文字是否在屏幕范围内都可以。
 楼主| 发表于 2003-11-3 16:41:00 | 显示全部楼层
to mccad:
  对了,我在打开这张dwg图时,发现通过VB调用Acad COM打开的AutoCAD2002窗口中所有的Text元素都不显示,而直接打开AutoCAD时却时显示。是不是和没有字体有关?因为在打开直接AutoCAD时,提示要求选择字体。而在通过VB调用COM接口时我没有指定相应的字体,有这个可能吗?
GMT+8, 2025-8-29 05:07 , Processed in 0.224072 second(s), 24 queries , Gzip On.
