查看: 1609|回复: 1
求教:用vba怎么画一个圆柱体,输入圆柱起点和终点坐标,圆柱半径?
发表于 2003-10-31 15:43:00 | 显示全部楼层 |阅读模式
发表于 2003-10-31 18:48:00 | 显示全部楼层
Sub AddCylinder()
    ' 例子演示了在模型空间创建一个圆柱体
    Dim cylinderObj As Acad3DSolid
    Dim radius As Double
    Dim center(0 To 2) As Double
    Dim height As Double
    ' 定义圆柱体
    center(0) = 0#: center(1) = 0#: center(2) = 0#
    radius = 5#
    height = 20#
    ' 在模型空间创建一个圆柱体(三维实体)
    Set cylinderObj = ThisDrawing.ModelSpace.AddCylinder(center, radius, height)
    ' 更改视口的视角,以观看圆柱体
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.Direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
End Sub
GMT+8, 2025-5-24 20:13 , Processed in 0.313650 second(s), 23 queries , Gzip On.
