查看: 1135|回复: 0
打开图纸时的问题(layout)
发表于 2003-10-31 17:14:00 | 显示全部楼层 |阅读模式
打开图纸时的问题(layout)
Acad::ErrorStatus readDwgFile(char* currentRootFolder,char* tempFolder,const char* fileName)
        char* fullfileName=new char[MAX_PATH];
        sprintf(fullfileName,"%s%s\\%s",currentRootFolder,tempFolder,fileName);
        AcDbDatabase* pCurDb;
        Acad::ErrorStatus es;
        AcDbDatabase* pDb = new AcDbDatabase(Adesk::kFalse);
        es=pDb->readDwgFile(fullfileName);
        if(es!=Acad::eOk)
                acutPrintf("\n The %c file was not found. ",fullfileName);
                delete pDb;
                return es;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        AcDbObjectId blockId;
        char *blockName = "tempBlock";
        if(pCurDb->insert(blockId,"tempBlock",pDb,true)!=Acad::eOk)
                delete pCurDb;
        delete pDb;
        return es;
上面代码不能打开图纸空间的信息。
我要打开附件中的那个图纸中的所有信息到当前打开dwg文件中。(当前是一个新建的dwg文件)
要怎么改写我的代码? 还有就是要得到当前的标注样式。
GMT+8, 2025-5-6 09:51 , Processed in 0.179661 second(s), 23 queries , Gzip On.
