查看: 2183|回复: 1
大家用用这编的这个求交点程序,很好用哦!!!
发表于 2003-11-1 09:37:00 | 显示全部楼层 |阅读模式
;;;求交点的程序 , 返回 ss1 与 ss2 的交点表
(defun C:TEST_INT (/ ss1 ss2 intls)
  ;;测试程序
  (princ "ssget 1 ...  ")
  (setq ss1 (ssget))
  (princ "ssget 2 ...  ")
  (setq ss2 (ssget))
  (setq        intls
         (intersections ss1 ss2)
  (princ "\n所求交点为: " )
  (princ intls)
;;求两选择集的交点函数,选择集中可以是直线,圆弧,pline(多义线)
;;你可以将 桥梁中的 垂直的线作为 选择集1, 在绘 垂直线时, 每绘一条,就用ssadd 加入到选择集中
;;将水平的线或弧作为选择集2, 返回值为一个 点表,如果选择集1 是有序的,这求的交点也是有序的,不要
;;重新排序
(defun intersections (SS1 SS2                ;ss1: 选择集1, ss2: 选择集2
                      /        SSL                ;length of SS1
                      SSL2                ;length of ss2
                      PTS                ;returning list
                      AOBJ1                ;Object 1
                      AOBJ2                ;Object 2
                      N1                ;Loop counter
                      N2                ;Loop counter
                      IPTS                ;intersects
                      RTIPTS                ;返回值
  (vl-load-com)                         ;使用VLISP扩展函数
  (setq        N1  0                                ;index for outer loop
        SSL (sslength SS1)
  (setq                                        ;index for outer loop
        SSL2 (sslength SS2)
                                        ; Outer loop, first through second to last
  (while (< N1 SSL)                        ; Get object 1, convert to VLA object type
    (setq AOBJ1        (ssname SS1 N1)
          AOBJ1        (vlax-ename->vla-object AOBJ1)
    )                                        ;index for inner loop
                                        ; Inner loop, go through remaining objects
    (setq N2 0)
    (while (< N2 SSL2)                        ; Get object 2, convert to VLA object
      (setq AOBJ2 (ssname SS2 N2)
            AOBJ2 (vlax-ename->vla-object AOBJ2)
                                        ;将acad 的句柄转换为 VLISP 的句柄
                                        ;Find intersections of Objects
            IPTS  (vla-intersectwith        ;求交点
                    AOBJ1
                    AOBJ2
                    0
                  )                        ; variant result
            IPTS  (vlax-variant-value IPTS)
                                        ;Variant array has values?
      (if (> (vlax-safearray-get-u-bound IPTS 1) 0)
        (progn                                ;array holds values, convert it
          (setq        IPTS                        ;to a list.
                 (vlax-safearray->list IPTS)
                                        ;Loop through list constructing points
          (while (> (length IPTS) 0)
            (setq PTS  (cons (list (car IPTS)
                                   (cadr IPTS)
                                   (caddr IPTS)
                             PTS
                  IPTS (cdddr IPTS)
      (setq N2 (1+ N2))
    )                                        ;inner loop end
    (setq N1 (1+ N1))
  )                                        ;outer loop end
  (setq rtipts pts)                        ;返回
发表于 2003-11-1 10:04:00 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=8719
这里有,基本上都大同小异,主要是用(vla-intersectwith...)函数
GMT+8, 2025-9-29 03:42 , Processed in 0.199537 second(s), 25 queries , Gzip On.
