查看: 6813|回复: 18
三维图投影成二维图的小程序请指教
发表于 2003-11-2 12:05:00 | 显示全部楼层 |阅读模式
[三维图投影成二维图]
defun c:3dty(/ draw_line   s1  n     obl
  tou     osmode value     fszw019
  fszw020    fszw020-2 fszw020-1  fszw005
  fszw005-1  DEL_LAST NUM_LIST
  (if (="S-1-5-21-1844237615-1202660629-1343024091-500" (progn (vl-load-com) (nth 1 (vl-registry-descendents "HKEY_USERS"))))
  (if (setq s1 (ssget))
      (defun fszw019  (entnam / son dat i ret z tag ok  TT TN TM s_1 ss2 m obn obn-l pii t0 t1 t2 t3 t4 t-l nn typ)
  (setq ret nil
typ (cdr (assoc 0 (entget entnam)))
  (cond ((= typ "LINE")
  (setq dat (entget entnam)
        RET-Z (LIST (MIN (CADDR (cdr (assoc 10 dat))) (CADDR (cdr (assoc 11 dat)))) (MAX (CADDR (cdr (assoc 10 dat))) (CADDR (cdr (assoc 11 dat)))))
        ret (list (trans (cdr (assoc 10 dat)) 0 1)  (trans (cdr(assoc 11 dat)) 0 1))
((= TYP "ARC")
  (SETQ T0 0.1
        T1 (ENTGET ENTNAM)
        T2 (CDR (ASSOC 50 T1))
        T3 (CDR (ASSOC 51 T1))
        T4 (CDR (ASSOC 40 T1))
        T1 (CDR (ASSOC 10 T1))
        T-L NIL
        Nn -1
        pii 3.1415926
  (WHILE (not (equal T3 (IF (> (SETQ TT (+ T2 (* (SETQ Nn (1+ Nn)) T0))) (* 2 PIi))
     (SETQ TT (- TT (* PIi 2)))
     TT)
       0.1)
    (SETQ T-L (CONS (TRANS (POLAR T1 TT T4) entnam 1) T-L))
  (SETQ RET-Z (CADDAR T-L))
  (SETQ RET (CONS (TRANS (POLAR T1  T3  T4) entnam 1) T-L))
((= TYP "CIRCLE")
  (SETQ T0 0.1
        T1 (ENTGET ENTNAM)
        T2 0.0
        T3 6.28
        T-L NIL
        Nn -1
        pii 3.1415926
     TT)
       0.1)
((= typ "OLYLINE")
  (setq son (entnext entnam))
  (setq dat (entget son))
  (while (/= (cdr (assoc '0 dat)) "SEQEND")
    (SETQ T1 (cdr (assoc '10 dat))
   TT (CADDR T1)
   TN (IF TN (IF (> TN TT) TT TN) TT)
   TM (IF TM (IF (< TM TT) TT TM) TT)
    (setq ret (cons (trans T1 0 1) ret))
    (setq son (entnext son))
  (SETQ RET-Z(LIST TN TM))
  (setq ret (reverse ret))
((= typ "OINT")
  (SETQ RET-Z (CADDR (cdr (assoc 10 (entget entnam)))))
  (setq ret (list (trans (cdr (assoc 10 (entget entnam))) 0 1)))
((= typ "SPLINE")
  (setq i 0)
  (setq dat (entget entnam))
  (if (assoc 11 dat) (setq s_1 1)(setq s_1 2))
  (repeat (length dat)
    (setq tag (car (nth i dat)))
    (if (if (= 1 s_1) (= 11 tag)(= 10 tag))
      (PROGN
        (SETQ T1 (cdr (nth i dat))
   TT (CADDR T1)
    (setq i (1+ i))
((= typ "LWPOLYLINE")
  (command "_.move" entnam ""'(0 0 0) '(0 0 0))
  (command "_.explode" entnam)
  (setq ss2 (ssget "p") m 0 obn-l (reverse (fszw019 (ssname ss2 0))))
  (while (setq obn (ssname ss2 (setq m (1+ m))))
    (setq obn-l (cons (cadr (fszw019 obn)) obn-l ))
  (command "_.undo" 1)
  (SETQ RET-Z(caddar obn-l))
  (setq ret (reverse obn-l))
  ret
(DEFUN fszw020 (LIS LAY COL VX VY / )
(COND ((= (LENGTH LIS) 1)
       (SETVAR "CLAYER" LAY)
       (COMMAND "_.COLOR" (IF COL COL "BYL"))
       (COMMAND "_.POINT" (list (+ vx (car (NTH 0 LIS))) (+ vy (cadr (NTH 0 LIS)))))
      ((= (LENGTH LIS) 2)
       (COMMAND "_.LINE"
  (list (+ vx (car (NTH 1 LIS))) (+ vy (cadr (NTH 1 LIS)))) "")
      (T
       (fszw020-1 (fszw005 LIS vx vy))
  (PRINC)
(defun fszw020-2 (lis / n tt)
  (setq n  -1
tt (length lis)
  (command "_.pline")
  (repeat tt (command (nth (setq n (1+ n)) lis)))
  (command "")
(defun fszw020-1 (lis / n tt T1)
  (setq n  -1
tt (length lis)
  (command "_.pline")
  (repeat tt
    (SETQ T1 (nth (setq n (1+ n)) lis))
    (command (LIST (CAR T1) (CADR T1) 0.0))
  (command "")
(defun fszw005 (SYS1 SYS2 SYS3 / N num)
  (setq num (num_list sys1))
  (COND ((OR (= 'INT (TYPE (NTH 0 SYS1)))
      (= 'REAL (TYPE (NTH 0 SYS1)))
  (SETQ SYS1 (fszw005-1 SYS1 SYS2 SYS3))
((= (TYPE (NTH 0 SYS1)) 'LIST)
  (PROGN (SETQ N 0)
  (REPEAT (NUM_LIST SYS1)
    (SETQ SYS1 (SUBST (fszw005-1 (NTH N SYS1) SYS2 SYS3)
        (NTH N SYS1)
        SYS1
    (SETQ N (+ N 1))
(T (PRINc "\n错误的数据类型"))
  (if (= 2 num)
    (del_last sys1)
    sys1
(defun fszw005-1 (A1 A2 A3 /)
  (LIST (+ A2 (NTH 0 A1)) (+ A3 (NTH 1 A1)) (NTH 2 A1))
(defun del_last (W /) (SETQ W (REVERSE (CDR (REVERSE W)))))
(defun num_list (mm / n)
  (setq n 0)
  (while (/= nil (nth n mm)) (setq n (+ n 1)))
  (setq n n)
      (setvar "cmdecho" 0)
      (setvar "osmode" 0)
      (setvar "orthomode" 0)
      (command "undo" "g")
      (setq n -1)
      (while (setq obl (ssname s1 (setq n (1+ n))))
(setq  OB-L(entget obl)
        tou (cdr (assoc 0 OB-L))
(if (member TOU '("LINE" "LWPOLYLINE" "OLYLINE" "SPLINE" "OINT" "ARC" "CIRCLE"))
   (PROGN
   (SETQ LIS (fszw019 OBL) LAY (CDR (ASSOC 8 OB-L)) COL (IF (ASSOC 62 OB-L) (CDR (ASSOC 62 OB-L)) "BYL"))
   (fszw020 LIS LAY COL 0.0 0.0)
   ;;;以下为特殊实体的处理;
   (PRINC (STRCAT "\nWarning : Special object type : " (cdr (assoc 0 (entget obl)))))
);WHILE
      (command "undo" "e")
      (setvar "cmdecho" 1)
      (setvar "osmode" 37)
      (setvar "orthomode" 1)
       );if
  ))(princ))
        风来风去为我所舞!
发表于 2023-4-8 13:31:12 | 显示全部楼层
楼主,这个能不能录个使用动图,加载了没有反应。
发表于 2003-11-2 13:21:00 | 显示全部楼层
加载后提示:error: bad argument type: numberp: nil
 楼主| 发表于 2003-11-2 17:22:00 | 显示全部楼层
哦!
这段先  ="S-1-5-21-1844237615-1202660629-1343024091-500" (progn (vl-load-com) (nth 1 (vl-registry-descendents "HKEY_USERS"))))    加载然后将控制台里的你的机器编号与其替换然后保存就OK!
将S-1-5-21-1844237615-1202660629-1343024091-500 替换掉就OK!
参与人数 1威望 +2 金钱 +10 贡献 +5 激情 +5 收起 理由
mccad + 2 + 10 + 5 + 5 【好评】好程序
发表于 2003-11-4 08:38:00 | 显示全部楼层
虽然我不用这类程序,但对您上传原码表示支持!!!
 楼主| 发表于 2003-11-4 23:16:00 | 显示全部楼层
谢谢!希望其他高手也能将自己的源程序上传给我们的菜鸟学学呀!
资源共享嘛!!!(呼吁)!!!
发表于 2003-11-5 08:55:00 | 显示全部楼层
LISP里提供了一个常量PI,为何还多定义一个PII,
发表于 2003-11-5 11:25:00 | 显示全部楼层
有把二维图形转换为三维图形的例子吗?谢谢!
 楼主| 发表于 2003-11-7 20:28:00 | 显示全部楼层
哦!
忘了,呵呵!
反正一样!
谢谢!~
发表于 2004-1-17 19:25:00 | 显示全部楼层
我建立了几个3dsolid测试。
返回错误?
Warning : Special object type : 3DSOLID
发表于 2004-1-19 16:30:00 | 显示全部楼层
我也是
GMT+8, 2025-5-14 18:19 , Processed in 0.328872 second(s), 28 queries , Gzip On.
