查看: 7806|回复: 14
[分享]公差编辑工具
发表于 2003-11-2 21:36:00 | 显示全部楼层 |阅读模式
由于AutoCAD的公差标注比较烦琐。所以做了一个,主要是参考一本机械方面的期刊(李忠群)做来的。做完后感觉进步较大,如有问题,欢迎提出批评和建议。
特此分享!
程序源码如下:
  1. '2003.11.2
  2. 'by gzy
  3. 'e-mail:gzy@mjtd.com
  4. Private Sub ComboBox1_Change()
  5.   Select Case UserForm.ComboBox1.Value
  6.   Case "无公差"
  7.   UserForm.TextBox1.Enabled = False
  8.   UserForm.TextBox2.Enabled = False
  9.   UserForm.TextBox3.Enabled = False
  10.   UserForm.TextBox3.BackColor = UserForm.BackColor
  11.   UserForm.TextBox1.BackColor = UserForm.BackColor
  12.   UserForm.TextBox2.BackColor = UserForm.BackColor
  13.   Case "对称公差"
  14.   UserForm.TextBox1.Enabled = False
  15.   UserForm.TextBox1.BackColor = UserForm.BackColor
  16.   UserForm.TextBox2.Enabled = True
  17.   UserForm.TextBox2.BackColor = UserForm.TextBox5.BackColor
  18.   UserForm.TextBox3.Enabled = False
  19.   UserForm.TextBox3.BackColor = UserForm.BackColor
  20.    Case "极限偏差"
  21.   UserForm.TextBox1.Enabled = False
  22.   UserForm.TextBox1.BackColor = UserForm.BackColor
  23.   UserForm.TextBox2.Enabled = True
  24.   UserForm.TextBox2.BackColor = UserForm.TextBox5.BackColor
  25.   UserForm.TextBox3.Enabled = True
  26.   UserForm.TextBox3.BackColor = UserForm.TextBox5.BackColor
  27.   Case "极限尺寸"
  28.   UserForm.TextBox1.Enabled = False
  29.   UserForm.TextBox1.BackColor = UserForm.BackColor
  30.   UserForm.TextBox2.Enabled = True
  31.   UserForm.TextBox2.BackColor = UserForm.TextBox5.BackColor
  32.   UserForm.TextBox3.Enabled = True
  33.   UserForm.TextBox3.BackColor = UserForm.TextBox5.BackColor
  34.   Case "基本偏差"
  35.   UserForm.TextBox1.Enabled = False
  36.   UserForm.TextBox1.BackColor = UserForm.BackColor
  37.   UserForm.TextBox2.Enabled = False
  38.   UserForm.TextBox2.BackColor = UserForm.BackColor
  39.   UserForm.TextBox3.Enabled = False
  40.   UserForm.TextBox3.BackColor = UserForm.BackColor
  41.   Case "用户定义"
  42.   UserForm.TextBox1.Enabled = True
  43.   UserForm.TextBox1.BackColor = UserForm.TextBox5.BackColor
  44.   UserForm.TextBox2.Enabled = True
  45.   UserForm.TextBox2.BackColor = UserForm.TextBox5.BackColor
  46.   UserForm.TextBox3.Enabled = True
  47.   UserForm.TextBox3.BackColor = UserForm.TextBox5.BackColor
  48.   End Select
  49.   End Sub
  50. Private Sub CommandButton1_Click() '编辑完毕
  51. UserForm.hide
  52. End Sub
  53. Private Sub CommandButton2_Click()
  54. End
  55. End Sub
  56. Private Sub UserForm_initialize() '对话框初始化
  57. UserForm.ComboBox1.AddItem "无公差", 0
  58. UserForm.ComboBox1.AddItem "对称公差", 1
  59. UserForm.ComboBox1.AddItem "极限偏差", 2
  60. UserForm.ComboBox1.AddItem "极限尺寸", 3
  61. UserForm.ComboBox1.AddItem "基本尺寸", 4
  62. UserForm.ComboBox1.AddItem "用户定义", 5
  63. UserForm.ComboBox1.Value = "无公差"
  64. UserForm.TextBox1.Enabled = False
  65. UserForm.TextBox1.BackColor = UserForm.BackColor
  66. UserForm.TextBox2.Enabled = False
  67. UserForm.TextBox2.BackColor = UserForm.BackColor
  68. UserForm.TextBox3.Enabled = False
  69. UserForm.TextBox3.BackColor = UserForm.BackColor
  70. End Sub
  71. Public Function simplify(dimtext, dstyle) '按系统设置的精度要求,对标注尺寸进行处理
  72.   If dstyle = 4 Then
  73.     dimdec = ThisDrawing.GetVariable("dimadec")
  74.   Else
  75.     dimdec = ThisDrawing.GetVariable("dimdec")
  76.   End If
  77.   seyle = "."
  78.    If dimdec > 0 Then
  79.       Do While dimdec > 0
  80.         style = style + "#"
  81.         dimdec = dimdec - 1
  82.       Loop
  83.       simplify = Format(dimtext, style)
  84.     Else
  85.        simplify = CInt(dimtext)
  86.    End If
  87. End Function
  88. Public Function detol(dimnm, dimtp, dimtm, textpre, textsuf) '分解公差各部分
  89.   dimnm = Left(dimnm, Len(dimnm) - Len(textsuf))
  90.   dimnm = Right(dimnm, Len(dimnm) - Len(textsuf))
  91. If InStr(dimnm, "%%p") <> 0 Then   '采用对称公差标注时
  92.     dimnum = Left(dimnm, InStr(dimnm, "%%p") - 1)
  93.     Else
  94.       pos1 = InStr(dimnm, "{")
  95.       If pos1 > 0 Then
  96.          dimnm = Left(dimnm, pos1 - 1)
  97.       End If
  98. End If
  99.       detol = dimnm
  100. End Function
  101. Public Function gentol(Text, tp, tm, prefix, profix, code) '将名义尺寸、上、下偏差等组合出公差
  102. Dim obj1 As AcadEntity
  103. textsize = ThisDrawing.GetVariable("dimtxt")
  104. tolsize = 0.6 * textsize
  105. Text = prefix + Text
  106. If Abs(tp) = Abs(tm) Then
  107.    If tp = 0 Then  '没有公差时
  108.      gentol = Text
  109.     Else
  110.       If Abs(tp) < 1 Then
  111.       gentol = Text + "%%p0" + Trim(Str(Abs(tp)))
  112.       Else: gentol = Text + "%%p" + Trim(Str(Abs(tp)))
  113.     End If
  114.   End If
  115. Else
  116.    Select Case tp
  117.      Case ls > 0
  118.      If tp < 1 Then
  119.        tp = "+0" + Trim(Str(tp))
  120.       Else: tp = "" + Trim(Str(tp))
  121.       End If
  122.       Case ls = 0
  123.         tp = "0"
  124.       Case ls < 0
  125.         If Abs(tp) < 1 Then
  126.           tp = Trim(Str(Abs(tp)))
  127.           tp = "-0" + tp
  128.           Else: tp = Trim(Str(tp))
  129.           End If
  130.           End Select
  131. Select Case tm
  132.    Case ls > 0
  133.      If tm < 1 Then
  134.         tm = "+0" + Trim(Str(tm))
  135.      Else: tm = "+" + Trim(Str(tm))
  136.      End If
  137.      Case ls = 0
  138.        tm = "0"
  139.        Case ls < 0
  140.         If Abs(tm) < 1 Then
  141.           tm = Trim(Trim(Abs(tm)))
  142.           tm = "-0" + tm
  143.         Else: tm = Trim(Str(tm))
  144.         End If
  145.         End Select
  146.         gentol = Text + "{\h" + tolsize + ";\s" + tp + "" + tm + ";}" + profix
  147.     End If
  148.     End Function
  149.     Public Sub dimedit() '公差编辑
  150.       Dim obj1 As AcadEntity
  151.       Dim curobj As AcadDimension
  152.       Do While code = 0
  153.         On Error Resume Next
  154.         ThisDrawing.Utility.GetEntity obj1, pnt1, "请选择要标注的尺寸"
  155.           If Err.Number = 0 Then
  156.           Select Case obj1.ObjectName ' 判断标注类型
  157.             Case "AcDbRotatedDimension"
  158.               code = 1
  159.             Case "AcDbAlignedDimension"
  160.               code = 1
  161.             Case "AcDbLinearDimension"
  162.               code = 1
  163.             Case "AcDbDiametricDimension"
  164.               code = 2
  165.             Case "AcDbRadialDimension"
  166.               code = 3
  167.            Case "AcDb2LineAngularDimension", "AcDb3PointAngularDimension"
  168.               code = 4
  169.           End Select
  170.           Else
  171.             Err.Clear
  172.           End If
  173.           Loop
  174.           Set curobj = obj1
  175.           UserForm.TextBox1.Text = simplify(curobj.Measurement, code)
  176.           Select Case curobj.ToleranceDisplay
  177.           Case "actolnone"
  178.              UserForm.ComboBox1.Value = "无公差"
  179.           Case "actolactollimitsdeviation"
  180.              UserForm.ComboBox1.Value = "极限偏差"
  181.           Case "actoactolimits"
  182.              UserForm.ComboBox1.Value = "极限尺寸"
  183.           Case "actolsymmetrical"
  184.              UserForm.ComboBox1.Value = "对称公差"
  185.           Case "actolbasic"
  186.              UserForm.ComboBox1.Value = "基本尺寸"
  187.           End Select
  188.   UserForm.TextBox2.Text = Format(curobj.ToleranceUpperLimit, "0.#")
  189.   UserForm.TextBox3.Text = Format(curobj.ToleranceLowerLimit, "0.#")
  190.        UserForm.TextBox4.Text = curobj.TextPrefix
  191.        UserForm.TextBox5.Text = curobj.TextSuffix
  192.        If curobj.TextOverride = "" Then '未使用文字替代时,从测量标注测量值获得对话框初始值
  193.        UserForm.TextBox1.Text = simplify(curobj.Measurement, code)
  194.        If code = 4 Then UserForm.TextBox1.Text = simplify(curobj.Measurement * 180 / pi, code)
  195.          Else '使用文字替代时,从替代字符串中分解出对话框初始值
  196.           UserForm.ComboBox1.Value = "用户定义"
  197.           temp = UCase(Trim(cruobj.TextOverride))
  198.            UserForm.TextBox1.Text = detol(temp, UserForm.TextBox2.Text, UserForm.TextBox3. _
  199.            Text, UserForm.TextBox4.Text, UserForm.TextBox5.Text)
  200.        End If
  201.        UserForm.Show
  202.        If UserForm.TextBox4.Text = "" Then '去掉前缀和后缀
  203.         curobj.TextPrefix = ""
  204.         End If
  205.       If UserForm.TextBox5.Text = "" Then
  206.         curobj.TextSuffix = ""
  207.         End If
  208.        curobj.TextPrefix = UserForm.TextBox4.Text
  209.        curobj.TextSuffix = UserForm.TextBox5.Text
  210.        curobj.ToleranceUpperLimit = UserForm.TextBox2.Text
  211.        curobj.ToleranceLowerLimit = UserForm.TextBox3.Text
  212.        curobj.TextOverride = ""
  213.        Select Case UserForm.ComboBox1.Value
  214.        Case "无公差"
  215.          curobj.ToleranceDisplay = acTolNone
  216.        Case "极限偏差"
  217.          curobj.ToleranceDisplay = acTolDeviation
  218.        Case "极限尺寸"
  219.          curobj.ToleranceDisplay = acTolLimits
  220.        Case "对称公差"
  221.          curobj.ToleranceDisplay = acTolSymmetrical
  222.        Case "基本尺寸"
  223.          curobj.ToleranceDisplay = acTolvasic
  224.        Case "用户定义"
  225.          curobj.TextOverride = gentol(UserForm.TextBox1.Text, _
  226.          UserForm.TextBox2.Text, UserForm.TextBox3.Text, _
  227.          UserForm.TextBox4.Text, UserForm.TextBox5.Text, code)
  228.        End Select
  229.        curobj.Update
  230.        curobj.Visible = True
  231.   End Sub
参与人数 1威望 +1 金钱 +2 贡献 +1 激情 +2 收起 理由
mccad + 1 + 2 + 1 + 2 【好评】好文章
发表于 2003-11-21 23:45:00 | 显示全部楼层
文件下载后怎么用呀?
发表于 2003-11-22 13:45:00 | 显示全部楼层
如何使用!
谢谢!
发表于 2003-11-22 13:48:00 | 显示全部楼层
用VAB加载后运行
 楼主| 发表于 2003-11-30 13:51:00 | 显示全部楼层
在模块中加载
发表于 2003-12-1 12:09:00 | 显示全部楼层
怎么用?是什么命令?
发表于 2003-12-6 23:10:00 | 显示全部楼层
斑竹,这个程序挺好,挺实用
如果能够自动将加入的公差文字的高度以尺寸文字高度的一定的比例(如0.6)显示就更好了
另外,修改过的尺寸如果也能用这个东东加公差的话那就更加妙了
最后请教斑竹一个问题:我怎么在Lisp程序中加载DVB文件,我现在是用手动加载,再运行宏
笨办法,呵呵
多谢!
发表于 2003-12-30 17:05:00 | 显示全部楼层
實用工具可不能錯過啊^^_^
发表于 2003-12-30 20:28:00 | 显示全部楼层
能够自动将加入的公差文字的高度以尺寸文字高度的一定的比例的程序 呵呵 算是对楼主的补充啊 不过没有楼主的那么全
希望大家批评指正啊
解压后 打开cad  把它加载到启动组中 然后每次只要双击标注尺寸就可以了
发表于 2004-1-5 12:21:00 | 显示全部楼层
修改过的尺寸用了后又返回真实值,如何解决?
GMT+8, 2025-6-6 14:14 , Processed in 0.202744 second(s), 25 queries , Gzip On.
