查看: 1446|回复: 1
〔求助〕vba中我想构造要一个改物体属性的函数
发表于 2003-11-6 15:07:00 | 显示全部楼层 |阅读模式
Public Sub ChangeAtt(ent As object, Att As String, value As Variant)
  With ent
  .Att = value
  End With
End Sub
其中ent表示实体,att是这个实体的一个属性,value是值
上面的程序运行到.Att = value时会出错,不知道有没有办法解决?
或者vba有自带的类似的函数?
发表于 2003-11-6 17:53:00 | 显示全部楼层
  1. ' 函数
  2. Sub SetAttValue(AttEnt As AcadBlockReference, Tag As String, Value As String)
  3.     Dim Att As AcadAttributeReference
  4.     If AttEnt.HasAttributes = True Then
  5.         Dim AttVal As Variant
  6.         AttVal = AttEnt.GetAttributes
  7.         Dim i As Integer
  8.         For i = 0 To UBound(AttVal)
  9.             If AttVal(i).TagString = Tag Then
  10.                 AttVal(i).TextString = Value
  11.             End If
  12.         Next i
  13.     End If
  14. End Sub
  15. ' 例子
  16. Sub mjtd()
  17.     Dim ent As AcadEntity
  18.     Dim pnt As Variant
  19.     ThisDrawing.Utility.GetEntity ent, pnt, "Get Block:"
  20.     SetAttValue ent, "CLBJ", "mjtd.com"
  21. End Sub
GMT+8, 2025-5-25 00:09 , Processed in 0.159653 second(s), 23 queries , Gzip On.
