查看: 2385|回复: 7
[LISP]求助-交点统计
发表于 2003-11-7 11:40:00 | 显示全部楼层 |阅读模式
如何能自动统计出一个范围里所有线的交点个数呢,尤其是线很多的情况下
急需。thank
发表于 2003-11-7 13:28:00 | 显示全部楼层
求出了所有交点,不是是否有些多余
  1. (defun GetInterPoint (ent1 ent2 / ax_ent_1 ax_ent_2 intpoints points i)
  2.   (setq ax_ent_1 (vlax-ename->vla-object ent1)
  3.         ax_ent_2 (vlax-ename->vla-object ent2)
  4.   )
  5.   (setq intpoints (vla-intersectwith ax_ent_1 ax_ent_2 acextendnone))
  6.   (setq intpoints (vlax-variant-value intpoints))
  7.   (setq i 0)
  8.   (if (> (vlax-safearray-get-u-bound intpoints 1) 0)
  9.     (repeat (/ (+ 1
  10.               (- (vlax-safearray-get-u-bound intpoints 1)
  11.                  (vlax-safearray-get-l-bound intpoints 1)
  12.               )
  13.            )
  14.            3
  15.         )
  16.       (setq points (append points (list (list
  17.                       (vlax-safearray-get-element intpoints i)
  18.                       (vlax-safearray-get-element intpoints (+ i 1))
  19.                       (vlax-safearray-get-element intpoints (+ i 2))
  20.                     )))
  21.       )
  22.       (setq i (+ 3 i))
  23.     )
  24.   )
  25.   points
  26. )
  27. (defun c:main( / ss n i j ent1 ent2 points)
  28.   (setq ss (ssget))
  29.   (if ss
  30.     (setq n (sslength ss))
  31.   )
  32.   (setq i 0 j 0)
  33.   (while (< i n)
  34.     (setq j (1+ i))
  35.     (setq ent1 (ssname ss i))
  36.     (while (< j n)
  37.       (setq ent2 (ssname ss j))
  38.       (setq points (append points (getinterpoint ent1 ent2)))
  39.       (setq j (1+ j))
  40.     )
  41.     (setq i (1+ i))
  42.   )
  43.   (Princ points)
  44.   (princ (strcat "\n共有交点" (itoa (length points)) "个"))
  45.   (princ)
  46. )
 楼主| 发表于 2003-11-7 15:22:00 | 显示全部楼层
谢谢提供程序,不过在试用的时候好象出了点问题,算不出来
Command: main
Select objects: Other corner: 6 found
Select objects:
error: null function
(VLAX-ENAME->VLA-OBJECT ENT1)
(SETQ AX_ENT_1 (VLAX-ENAME->VLA-OBJECT ENT1) AX_ENT_2 (VLAX-ENAME->VLA-OBJECT
ENT2))
(GETINTERPOINT ENT1 ENT2)
(APPEND POINTS (GETINTERPOINT ENT1 ENT2))
(SETQ POINTS (APPEND POINTS (GETINTERPOINT ENT1 ENT2)))
(WHILE (< J N) (SETQ ENT2 (SSNAME SS J)) (SETQ POINTS (APPEND POINTS
(GETINTERPOINT ENT1 ENT2))) (SETQ J (1+ J)))
(WHILE (< I N) (SETQ J (1+ I)) (SETQ ENT1 (SSNAME SS I)) (WHILE (< J N) (SETQ
ENT2 (SSNAME SS J)) (SETQ POINTS (APPEND POINTS (GETINTERPOINT ENT1 ENT2)))
(SETQ J (1+ J))) (SETQ I (1+ I)))
(C:MAIN)
*Cancel*
不知道该如何解决,希望帮助 thank
发表于 2003-11-7 15:25:00 | 显示全部楼层
先运行(vl-load-com)
发表于 2003-11-7 15:32:00 | 显示全部楼层
henai发表于2003-11-7 15:22:00谢谢提供程序,不过在试用的时候好象出了点问题,算不出来
Command: main
Select objects:
你的好象是R14吧,这个程序用不了,说说你的线都是什么类型,如果都是LINE或PLINE的话还好办
 楼主| 发表于 2003-11-7 16:20:00 | 显示全部楼层
都是line,只是想知道有多少个交点,这样可以知道要布多少管
另外问一下 刚才的2002下还能用呀?
 楼主| 发表于 2003-11-7 16:28:00 | 显示全部楼层
2002下可以用使用,thank
发表于 2003-11-7 17:15:00 | 显示全部楼层
R14可用程序
  1. (defun Getinterpoints(ent1 ent2 / e1 e2 pt1 pt2 pt3 pt4)
  2.   (setq e1 (entget ent1))
  3.   (setq e2 (entget ent2))
  4.   (setq pt1 (cdr (assoc 10 e1)))
  5.   (setq pt2 (cdr (assoc 11 e1)))
  6.   (setq pt3 (cdr (assoc 10 e2)))
  7.   (setq pt4 (cdr (assoc 11 e2)))
  8.   (inters pt1 pt2 pt3 pt4)
  9. )
  10. (defun c:main( / ss n i j ent1 ent2 points point)
  11.   (setq ss (ssget '((0 . "line"))))
  12.   (if ss
  13.     (setq n (sslength ss))
  14.   )
  15.   (setq i 0 j 0)
  16.   (while (< i n)
  17.     (setq j (1+ i))
  18.     (setq ent1 (ssname ss i))
  19.     (while (< j n)
  20.       (setq ent2 (ssname ss j))
  21.       (if (setq point (getinterpoints ent1 ent2))
  22.         (setq points (append points (list point)))
  23.       )
  24.       (setq j (1+ j))
  25.     )
  26.     (setq i (1+ i))
  27.   )
  28.   (Princ points)
  29.   (princ (strcat "\n共有交点" (itoa (length points)) "个"))
  30.   (princ)
  31. )
GMT+8, 2025-6-10 06:08 , Processed in 0.188983 second(s), 25 queries , Gzip On.
