- 积分
- 74305
- 明经币
- 个
- 注册时间
- 2001-6-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2003-11-13 11:42:00
显示全部楼层
没有时间整理好一点,也没有加入出错捕捉语句:
- Sub ExObjs()
- '先取得要外扩的图形做为选择集;
- Dim ss As AcadSelectionSet
- Set ss = CreateSelectionSet
- ss.SelectOnScreen
- Dim z As Double
- z = ThisDrawing.Utility.GetDistance(, "输入扩边的距离:")
- '通过选择集的每一对象取得总的选择集的长(X)和宽(Y)以及中心CP)(用GetBoundingBox方法 );
- Dim box As Variant
- box = ssExtents(ss)
- Dim cp As Variant
- Dim x As Double
- Dim y As Double
- cp = GetCenterPoint(box, x, y)
- '按照需要的外扩的值(Z)计算X向和Y向的插入比例:
- Dim x1 As Double
- Dim y1 As Double
- x1 = (x + 2 * z) / x
- y1 = (y + 2 * z) / y
- '将选择集生成的图块
- Dim objBlk As AcadBlock
- Set objBlk = ThisDrawing.Blocks.Add(cp, "*U")
- Dim varObjs As Variant
- varObjs = sset2var(ss)
- ThisDrawing.CopyObjects varObjs, objBlk
- Dim blkName As String
- blkName = objBlk.Name
- Dim blkref As AcadBlockReference
- Set blkref = ThisDrawing.ModelSpace.InsertBlock(cp, blkName, x1, y1, 1, 0)
- 'blkref.Explode
- 'blkref.Delete
- End Sub
- Function GetCenterPoint(points As Variant, ByRef x As Double, ByRef y As Double) As Variant
- Dim i As Integer
- Dim cp(2) As Double
- Dim MaxPnt As Variant
- Dim MinPnt As Variant
- MinPnt = points(0)
- MaxPnt = points(1)
- cp(0) = (MinPnt(0) + MaxPnt(0)) / 2
- cp(1) = (MinPnt(1) + MaxPnt(1)) / 2
- x = MaxPnt(0) - MinPnt(0)
- y = MaxPnt(1) - MinPnt(1)
- GetCenterPoint = cp
- End Function
- Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
- On Error Resume Next
- Set ss = ThisDrawing.SelectionSets(ssName)
- If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
- ss.Clear
- Set CreateSelectionSet = ss
- End Function
- Public Function Extents(points)
- Dim min, max
- Dim i As Long, j As Long, pt, retVal(0 To 1)
- min = points(LBound(points))
- max = points(LBound(points))
- For i = LBound(points) To UBound(points)
- pt = points(i)
- For j = LBound(pt) To UBound(pt)
- If pt(j) < min(j) Then min(j) = pt(j)
- If pt(j) > max(j) Then max(j) = pt(j)
- Next
- Next
- retVal(0) = min: retVal(1) = max
- Extents = retVal
- End Function
- Public Function ssExtents(ss As AcadSelectionSet) As Variant
- Dim points(), c As Long
- Dim min, max, util As AcadUtility
- Set util = ThisDrawing.Utility
- c = 0
- For i = 0 To ss.Count - 1
- ss.Item(i).GetBoundingBox min, max
- min = util.TranslateCoordinates(min, acWorld, acUCS, False)
- max = util.TranslateCoordinates(max, acWorld, acUCS, False)
- ReDim Preserve points(0 To c + 1)
- points(c) = min: points(c + 1) = max
- c = c + 2
- Next
- ssExtents = Extents(points)
- End Function
- Function sset2var(ss As AcadSelectionSet) As Variant
- Dim i As Integer
- Dim varObjs() As AcadEntity
- i = ss.Count - 1
- ReDim varObjs(i) As AcadEntity
- Set varObjs(i) = ss(i)
- Next
- sset2var = varObjs
- End Function
