查看: 2123|回复: 3
如何取得窗口坐标
发表于 2003-11-21 14:14:00 | 显示全部楼层 |阅读模式
如何取得绘图窗口的坐下电和右上角的坐标值?
发表于 2003-11-21 15:26:00 | 显示全部楼层
(defun C:TT ()
  (command "_.UCS" "V")
  (setq CTR (getvar "VIEWCTR"))
  (setq SIZE (getvar "VIEWSIZE"))
  (setq SCREEN (getvar "SCREENSIZE"))
  (setq SCALE (/ (car SCREEN) (cadr SCREEN)))
  (setq XSIZE (* SCALE SIZE))
  (setq RT (list (+ (car CTR) (/ XSIZE 2)) (+ (cadr CTR) (/ SIZE 2))))
  (setq LB (list (- (car CTR) (/ XSIZE 2)) (- (cadr CTR) (/ SIZE 2))))
  (command "_.line" RT LB "")
  (command "_.UCS" "")
参考:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=12315
牛B呀  发表于 2016-12-19 17:51
 楼主| 发表于 2003-11-21 16:51:00 | 显示全部楼层
谢谢!
GMT+8, 2025-10-21 05:11 , Processed in 0.187123 second(s), 27 queries , Gzip On.
