查看: 2066|回复: 3
如何在VBA修改LINETYPE GENARATION的属性值!
发表于 2003-11-24 17:33:00 | 显示全部楼层 |阅读模式
如何在VBA对选择的多段线修改LINETYPE GENARATION的属性值!
发表于 2003-11-24 20:07:00 | 显示全部楼层
LinetypeGeneration
Boolean; read-write
TRUE: Generates the linetype in a continuous pattern through the polyline vertices.
FALSE: Generates the linetype starting and ending with a dash at each polyline vertex.
Remarks
This property does not apply to polylines with tapered segments.
A polyline with linetype generation set to true (left) and set to false (right)
区别就在交点处吧,为True时是使用连续的线型,为False使用点做为开始和结束的分隔。
 楼主| 发表于 2003-11-25 08:04:00 | 显示全部楼层
斑竹,可是我图中有一些多段线在LinetypeGeneration为DISNABLE时总是显示不正确,而我将LinetypeGeneration改成ENABLED,就能正确显示。
希望能够修改这属性来解决这问题。
谢谢!
发表于 2003-11-27 12:46:00 | 显示全部楼层
  1. Sub kkk()
  2. Dim acaddoc As AcadDocument
  3. Dim selectset1 As AcadSelectionSet
  4. Set acaddoc = ThisDrawing
  5. On Error Resume Next
  6. Set selectset1 = acaddoc.SelectionSets("kkk")
  7. If Err Then
  8. Set selectset1 = acaddoc.SelectionSets.Add("kkk")
  9. End If
  10. selectset1.SelectOnScreen
  11. Dim entry As AcadEntity
  12.     For Each entry In selectset1
  13.          If entry.ObjectName = "AcDbPolyline" Then
  14.
  15.             entry.LinetypeGeneration = True
  16.     End If
  17.     Next entry
  18. selectset1.Clear
  19. End Sub
GMT+8, 2025-5-24 23:43 , Processed in 0.158958 second(s), 24 queries , Gzip On.
