查看: 3275|回复: 4
我想计算将面域的形心移动到0,0点然后计算惯性矩,可奇次和偶次计算结果不一样
发表于 2002-7-13 14:24:00 | 显示全部楼层 |阅读模式
我想计算将面域的形心移动到0,0点然后计算惯性矩,可奇次和偶次计算结果不一样,具体的说就是形心坐标第偶次计算又回到初始的位置:(,程序如下
Private Sub CommandButton1_Click()
    UserForm1.Hide
    Dim currUCS As AcadUCS
    Dim origin(0 To 2) As Double
    Dim Centroid As Variant
    Dim momentOfInertia As Variant
    Dim sset As AcadSelectionSet         'Define sset as a SelectionSet object
    'Set sset to a new selection set named SS1 (the name doesn't matter here)
    Set sset = ThisDrawing.SelectionSets.Add("SS1")
    sset.SelectOnScreen                  'Prompt user to select objects
    Dim ent As Object                    'Define ent as an object
    For Each ent In sset                 'Loop through the SelectionSet collection
        If ent.EntityName = "AcDbRegion" Then
            Centroid = ent.Centroid
            ' Create a UCS and makes it current
            Set currUCS = ThisDrawing.ActiveUCS
            origin(0) = Centroid(0): origin(1) = Centroid(1): origin(2) = 0
            currUCS.origin = origin
            ThisDrawing.ActiveUCS = currUCS
            momentOfInertia = ent.momentOfInertia
            MsgBox "Ix=" & Format(momentOfInertia(0) / 10000, "######.00") & "mm^4;Iy=" & Format(momentOfInertia(1) / 10000, "######.00") & "mm^4", , "被选择物体的惯性矩"
            End If
    Next ent
    sset.Delete
    UserForm1.Show
End Sub
发表于 2002-7-15 12:53:00 | 显示全部楼层
origin的原因
通过单步调试,我发现奇次和偶次计算时,currUCS.origin和ThisDrawing.ActiveUCS.origin不一样,暂未找到解决办法,有空我再试试。
 楼主| 发表于 2002-7-16 14:06:00 | 显示全部楼层
快来帮忙呀:(
帮我调试调试,我做不出来。
发表于 2002-7-16 16:03:00 | 显示全部楼层
找到原因了,先这样解决
找到原因了,Thisdrawing.ActiveUCS是活动UCS而不是系统UCS,计算转动惯量时以Thisdrawing.ActiveUCS的原点为中心,第一次运行时,以面域形心(注意:形心坐标非零,即不是系统UCS原点)为惯性中心;第二次运行时,形心坐标计算以Thisdrawing.ActiveUCS为参照,为零,惯性中心为(0,0)即系统UCS原点与面域形心不同。
解决办法:在修改Thisdrawing.ActiveUCS前保存原点,MsgBox后恢复。请参考以下代码。
    UserForm1.Hide
    Dim temp(0 To 2) As Double
    'save current UCS origin
   temp(0) = ThisDrawing.ActiveUCS.origin(0)
   temp(1) = ThisDrawing.ActiveUCS.origin(1)
   temp(2) = ThisDrawing.ActiveUCS.origin(2)
        End If
    Next ent
    currUCS.origin = temp
    ThisDrawing.ActiveUCS = currUCS  'restore ActiveUCS origin
    sset.Delete
    UserForm1.Show
End Sub
 楼主| 发表于 2002-7-17 17:49:00 | 显示全部楼层
thx
GMT+8, 2025-4-28 17:37 , Processed in 0.199757 second(s), 24 queries , Gzip On.
