查看: 11973|回复: 21
通过鼠标点取数字进行求和、求积的程序
发表于 2003-12-1 19:08:00 | 显示全部楼层 |阅读模式
Sub opsum()
Dim ss As AcadSelectionSet
Set ss = GetSelSet
Dim i As Integer
Dim a As Double
Dim ent As AcadEntity
For Each ent In ss
a = ent.textString
e = a
d = d + e
Dim ent2height As String
ent2height = ent.height
Next
f = FormatNumber(d, 3, vbture, , vbFalse)
Dim text2 As String
ThisDrawing.Utility.InitializeUserInput 0, "1 2"
text2 = ThisDrawing.Utility.GetKeyword(vbCrLf & 选项"[更改(1)/插入(2)](1): ")
If text2 = "" Or text2 = "1" Then text2 = "1"
If text2 = "1" Then
Dim ent1 As AcadEntity
ThisDrawing.Utility.GetEntity ent1, pt1, "选择更改数字:"
ent1.textString = f
End If
If text2 = "2" Then
Dim pt2 As Variant
Dim ent2 As AcadText
pt2 = ThisDrawing.Utility.GetPoint(, "插入:")
Set ent2 = ThisDrawing.ModelSpace.AddText(f, pt2, ent2height)
End If
End Sub
Sub opmul()
Set ss = GetSelSet
Dim a As Double
Dim d As Double
d = 1
For Each ent In ss
a = ent.textString
e = a
d = d * e
Dim height As String
height = ent.height
Next
On Error Resume Next
text2 = ThisDrawing.Utility.GetKeyword(vbCrLf & "选项[更改(1)/插入(2)](1): ")
If text2 = "1" Then
ent1.textString = f
End If
If text2 = "2" Then
Dim pt2 As Variant
pt2 = ThisDrawing.Utility.GetPoint(, "插入点:")
Set ent2 = ThisDrawing.ModelSpace.AddText(f, pt2, height)
End If
End Sub
Function GetSelSet() As AcadSelectionSet
Dim ssName As String
ssName = "ICKFIRST"
Set ss = ThisDrawing.SelectionSets.add(ssName)
If Err Then
Set ss = ThisDrawing.SelectionSets(ssName)
ss.Delete
End If
Set ss = ThisDrawing.PickfirstSelectionSet
If ss.Count = 0 Then
If Err Then Set ss = ThisDrawing.SelectionSets.add(ssName)
ss.Clear
ss.SelectOnScreen
End If
Set GetSelSet = ss
ThisDrawing.SetVariable "filedia", 1
End Function
参与人数 1贡献 +1 激情 +1 收起 理由
王咣生 + 1 + 1 【好评】奖励
发表于 2003-12-2 09:09:00 | 显示全部楼层
这句有错误,引号的位置不对。
特意为什么功能编的?输出数据确定为3位小数。象标高
发表于 2003-12-2 15:30:00 | 显示全部楼层
刚翻译到SuppressTrailingZeros 属性,想起你这个程序。
  觉得你可以使用该属性去控制小数后面的0。
 楼主| 发表于 2003-12-3 12:56:00 | 显示全部楼层
统计材料表时不用按计算器了啊,用鼠标点就可以了:)
发表于 2003-12-3 13:13:00 | 显示全部楼层
哦,我做结构的,不用材料表,不熟悉。
如果材料表的项数和每一项名称都固定。用属性做个属性块。让属性块里面的数据自动求和求乘积也不错。
我的钢筋表就是这样做的。
发表于 2003-12-3 15:13:00 | 显示全部楼层
用属性块好还是用扩展数据好?我觉得给对象添加扩展数据蛮有用的。
发表于 2003-12-29 00:48:00 | 显示全部楼层
good
发表于 2003-12-29 19:35:00 | 显示全部楼层
subtlation发表于2003-12-2 9:09:00text2 = ThisDrawing.Utility.GetKeyword(vbCrLf & 选项"(1): ")
这句有错误,引号的位置不对。
text2 = ThisDrawing.Utility.GetKeyword(vbCrLf & 选项 & "[更改(1)/插入(2)](1): ")
另外有个formatnumber函数没有,运行不了(autocad2000 EN)
等有空了仔细看看,我也向做个一样功能的.谢谢搂主.
 楼主| 发表于 2004-1-6 15:44:00 | 显示全部楼层
是统计材料明细表用的,我们专业没有专业的二次开发软件,都是在cad下画图,至于一些材料明细表都是拷贝上次的图进行修改,这样在计算时比较麻烦,就写了这个程序,计算时直接在屏幕上选取数值就可以进行求和、求积的计算了,图省事。formatnumber是格式化数字格式的,我不知道是不是需要装vb6.0才能用啊,我们同事没有装vb6.0的用的都挺好。(cad2002)
发表于 2004-4-15 12:35:00 | 显示全部楼层
subtlation发表于2003-12-3 13:13:00哦,我做结构的,不用材料表,不熟悉。如果材料表的项数和每一项名称都固定。用属性做个属性块。让属性块里面的数据自动求和求乘积也不错。我的钢筋表就是这...
我也是做结构的,但我对程序还不怎么懂,我们的材料表中一般要统计的数字是这样的 钢板的格式 单重 数量 总重 -20x120x120 20 2 40 我想单重通过钢板的格式中提取数据求得,总重又通过单重和数量的乘积得出 怎么弄这个程序呢? 你说你的钢筋材料表是这么统计的吗?
GMT+8, 2025-5-10 15:35 , Processed in 0.179476 second(s), 25 queries , Gzip On.
