查看: 1613|回复: 2
[求助]关于Select?
发表于 2003-12-10 15:54:00 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2003-12-10 16:42:00 | 显示全部楼层
看看对象模型http://www.mjtd.com/object/acad2004/
下面是个具体的例子
  1. Sub Example_SelectByPolygon()
  2.     ' This example adds entities to a selection set by defining a polygon.
  3.
  4.     Dim ssetObj As AcadSelectionSet
  5.     Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET2")
  6.
  7.     ' Add all the entities that lie within a fence to the selection set
  8.     Dim mode As Integer
  9.     Dim pointsArray(0 To 11) As Double
  10.     mode = acSelectionSetFence
  11.     pointsArray(0) = 28.2: pointsArray(1) = 17.2: pointsArray(2) = 0
  12.     pointsArray(3) = -5: pointsArray(4) = 13: pointsArray(5) = 0
  13.     pointsArray(6) = -3.3: pointsArray(7) = -3.6: pointsArray(8) = 0
  14.     pointsArray(9) = 28: pointsArray(10) = -3: pointsArray(11) = 0
  15.
  16.     ssetObj.SelectByPolygon mode, pointsArray
  17.
  18.     ' Add all the Circles that lie within fence to the selection set
  19.     ReDim gpCode(0 To 1) As Integer
  20.     gpCode(0) = 0
  21.     gpCode(1) = 10
  22.
  23.     Dim pnt(0 To 2) As Double
  24.     pnt(0) = 3: pnt(1) = 6: pnt(2) = 0
  25.
  26.     ReDim dataValue(0 To 1) As Variant
  27.     dataValue(0) = "Circle"
  28.     dataValue(1) = pnt
  29.
  30.     Dim groupCode As Variant, dataCode As Variant
  31.     groupCode = gpCode
  32.     dataCode = dataValue
  33.
  34.     ssetObj.SelectByPolygon mode, pointsArray, groupCode, dataCode
  35.
  36. End Sub
 楼主| 发表于 2003-12-10 16:51:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-10-18 05:46 , Processed in 0.172352 second(s), 23 queries , Gzip On.
