查看: 1519|回复: 0
自己写的一个多边形选择的例子
发表于 2003-12-11 11:43:00 | 显示全部楼层 |阅读模式
  1. Sub selecebypoly()
  2. Dim acaddoc As AcadDocument
  3. Dim k As Integer, i As Integer
  4. Dim pointarrays() As Double
  5. Dim retent As Object
  6. Dim tpolyline As AcadLWPolyline
  7. Dim sel1 As AcadSelectionSet
  8. On Error Resume Next
  9. Set acaddoc = ThisDrawing
  10. Set sel1 = acaddoc.SelectionSets("zjsel")
  11. If Err Then
  12. Err.Clear
  13. Set sel1 = acaddoc.SelectionSets.Add("zjsel")
  14. End If
  15. sel1.Clear
  16. Set retent = getneedobject(acaddoc)  '获得多边形
  17. If retent.ObjectName = "AcDbPolyline" Then
  18. Set tpolyline = retent
  19. Else
  20. End
  21. End If
  22. k = UBound(tpolyline.Coordinates)
  23. k1 = (k + 1) * 1.5
  24. ReDim pointarrays(0 To k1 - 1)
  25. For i = 0 To k1 / 3 - 1 Step 1                  '把坐标赋值给数组
  26. pointarrays(i * 3) = tpolyline.Coordinates(i * 2)
  27. pointarrays(i * 3 + 1) = tpolyline.Coordinates(i * 2 + 1)
  28. pointarrays(i * 3 + 2) = 0
  29. Next
  30. sel1.SelectByPolygon acSelectionSetWindowPolygon, pointarrays
  31. MsgBox sel1.Count
  32. End Sub
  33. Function getneedobject(acaddoc As AcadDocument) As Object
  34. On Error Resume Next
  35. Dim retent As Object
  36. Dim pnt As Variant
  37. acaddoc.Utility.GetEntity retent, ont, "选择一个闭合多边形"
  38. Dim errnum As Integer
  39. errnum = 0
  40. While Err
  41.       Err.Clear
  42.     errnum = errnum + 1
  43.     If errnum < 3 Then
  44.       acaddoc.Utility.GetEntity retent, ont, "选择一个闭合多边形"
  45.     Else
  46.     End
  47.     End If
  48. Wend
  49. Set getneedobject = retent
  50. End Function
参与人数 1威望 +1 金钱 +2 贡献 +1 激情 +2 收起 理由
zfbj + 1 + 2 + 1 + 2 【好评】好内容
GMT+8, 2025-2-21 03:32 , Processed in 0.147185 second(s), 24 queries , Gzip On.
