查看: 1246|回复: 1
求助:菜单增加了,但是宏却不能运行
发表于 2003-12-12 10:48:00 | 显示全部楼层 |阅读模式
我用程序实现菜单的增加
Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("myMenu")
    ' Add a menu item to the new menu
    Dim newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    Macro = Chr(3) & Chr(3) & Chr(95) & "D:\程序\CAD二次开发\BOM.dvb!M1.InitializeEvents" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.Count + 1, "open", Macro)
    ' Display the menu on the menu bar
    currMenuGroup.Menus.InsertMenuInMenuBar "myMenu", ""
菜单增加正常,但是宏却运行不起来,怎么回事啊
发表于 2003-12-12 11:14:00 | 显示全部楼层
Set newmenuitemname = newmenu.AddMenuItem(newmenu.Count + 2, "标注程序", "-vbarun u2 ")
  u2为具体过程。
GMT+8, 2025-5-10 14:44 , Processed in 0.157173 second(s), 23 queries , Gzip On.
