查看: 2271|回复: 3
怎样用lisp获得多义线的各顶点以及各段是直线还是圆弧
发表于 2003-12-12 19:29:00 | 显示全部楼层 |阅读模式
大侠们,怎样用lisp获得多义线的各顶点以及各段是直线还是圆弧?!!
发表于 2003-12-12 20:07:00 | 显示全部楼层
顶点是组码10
组码43,0就是直线,不是0就是圆弧
发表于 2003-12-13 17:41:00 | 显示全部楼层
还是基础知识呀
发表于 2003-12-17 15:45:00 | 显示全部楼层
列出顶点:
(defun c:test ()
  (setq obj (car (entsel "\nSelect a Polyline: ")))
  (foreach x (entget obj)
    (if (eq 10 (car x))(setq nlist (cons (cdr x) nlist)))
  (reverse nlist)
列出所点击子段序号, 坐标及凸度:
(defun c:test ( / en j oldos ss)
  (cond ((setq ent (entsel "ick a polyline: "))
         (getSegment (vlax-ename->vla-object (car ent))
                     (cadr ent)
(defun getSegment (obj pt / cpt eParam stParam)
  (cond ((setq cpt (vlax-curve-getClosestPointTo obj pt T))
         (setq eParam (fix (vlax-curve-getEndParam obj)))
         (setq bul (vla-getBulge obj (fix (vlax-curve-getParamAtPoint obj cpt))))
         (if (= eParam (setq stParam (fix (vlax-curve-getParamAtPoint obj cpt))))
           (setq stParam (1- stParam))
           (setq eParam (1+ stParam))
         (list eParam (vlax-curve-getPointAtParam obj stParam)
               (vlax-curve-getPointAtParam obj eParam) bul)
GMT+8, 2025-5-14 18:56 , Processed in 0.187238 second(s), 25 queries , Gzip On.
