查看: 1851|回复: 2
CAD是近视眼的怪异现象
发表于 2003-12-18 12:28:00 | 显示全部楼层 |阅读模式
用以下中心线标注程式标注中心线时,当画一个很小的圆如1--3mm直径,并将图视口范围放大到看到圆只是一个很小的圈时,用此程式选取圆画中心线,无法成功,,,只能画出一条水平中心线或一个中心点.......
将视口变小,圆看得清晰一些大一些一切正常!
(defun c:center-5( / ss i j ent ents ptc r pts)
(command "undo" "be")
(command "ltscale" "0.2" "" "")
(if (=(tblobjname "LAYER" "center") nil)
     (command "-layer" "m" "center" "c" 1 "" "L" "center" "" ""))
(command "-layer" "s" "center" "")
  (setq ss (ssget '((0 . "CIRCLE"))))
  (setq i 0)
  (repeat (sslength ss)
    (setq ent (ssname ss i))
    (setq ents (entget ent))
    (setq ptc (cdr (assoc 10 ents))
   r (cdr (assoc 40 ents))
   j 0
   pts'())
    (repeat 4
      (setq pts (append pts (list (polar ptc (* j (/ pi 2)) (+ r (/ r 3))))))
      (setq j (1+ j))
    (command "_.line" (nth 0 pts) (nth 2 pts) ""
      "_.line" (nth 1 pts) (nth 3 pts) "")
    (setq i (1+ i))
发表于 2003-12-18 12:44:00 | 显示全部楼层
程序开头加上(setvar "osmode" 0)再试试
 楼主| 发表于 2003-12-18 13:11:00 | 显示全部楼层
OK!OK!感请版主!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2025-5-14 18:05 , Processed in 0.182924 second(s), 25 queries , Gzip On.
