查看: 2632|回复: 4
本网站提供的autosheet怎么用
发表于 2002-7-21 15:34:00 | 显示全部楼层 |阅读模式
发表于 2002-7-22 20:45:00 | 显示全部楼层
呵,金兄已到外国了,我发的信收到了吧,有关AutoSheet的几个问题
发表于 2002-7-21 17:37:00 | 显示全部楼层
菜单会自动增加AutoSheet菜单
1可以点击autosheet来弹出主窗口
2在窗口的表格中输入内容,与Excel一样的输入。
3.输入完毕后点击左侧下部的绘制(DRAW)就可以在AutoCAD中绘制表格了。
发表于 2002-7-22 19:31:00 | 显示全部楼层
something is wrong
If there is not "AutoSheet" menu showed  aftere running setup.exe,pleases do the follow 2 steps:
1.Add support path;
2.menuload the autoSheet menu.
Then close the AutoCAD and open the AutoCAD again.You can run AutoSheet from the "AutoSheet" menu.
Now I haven't enough time to finish this software. I will do it better days later.
Thank you very much if you find anything wrong about the software and email to me.
发表于 2002-7-23 15:16:00 | 显示全部楼层
Yeah,Thank you very much.
I will finish it later.
I will use excelXP's controls to do it.
Any way, Thank you very much.
GMT+8, 2025-4-28 16:24 , Processed in 0.165225 second(s), 28 queries , Gzip On.
