查看: 1402|回复: 0
VBA中功能都可以实现,但在VB中还是没有办法捕捉,见代码!
发表于 2003-12-23 20:30:00 | 显示全部楼层 |阅读模式
Option Explicit
Private Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer
Private Const VK_ESCAPE = &H1B
Dim acadapp As AcadApplication
Dim acaddoc As AcadDocument
Private Sub Form_Load()
Me.Hide
    Dim ESC As Long
    GetAsyncKeyState VK_ESCAPE
    On Error GoTo Err_Control
    Dim Pnt1 As Variant
    Dim Pnt2 As Variant
    Dim line As AcadLine
    Dim varCancel As Variant
    Set acadapp = GetObject(, "AutoCAD.application")
    Set acaddoc = acadapp.ActiveDocument
    Pnt1 = acaddoc.Utility.GetPoint(, vbCr & "选择第一点:")
    Do
        Pnt2 = acaddoc.Utility.GetPoint(Pnt1, vbCr & "选择下一点:")
        Set line = acaddoc.ModelSpace.AddLine(Pnt1, Pnt2)
        Pnt1 = Pnt2
    Loop
Exit_Here:
  Exit Sub
Err_Control:
    varCancel = acaddoc.GetVariable("LASTPROMPT")
    ESC = GetAsyncKeyState(VK_ESCAPE)
    Select Case Err.Number
        '按了取消键或其它透明命令
        Case -2147352567
            '如果命令行提示中没有“取消”这样的文字出现
            '一般来说在2002中按了回车或空格都不会出现“取消”
            '则退出
            If InStr(1, varCancel, "*Cancel*") <> 0 And _
               InStr(1, varCancel, "*取消*") <> 0 Then
                Err.Clear
                Resume Exit_Here
            '如果按了ESC键,则退出
            ElseIf ESC <> 0 Then
                Err.Clear
                Resume Exit_Here
            '其它情况下,则恢复。如选择了透明命令,则会出现“取消”
            '字样,但不是按了“取消”键。
            Else
                Err.Clear
                Resume
            End If
        '右键单击或回车或空格。
        '在这里,-2147467259用于AutoCAD 2000 及2002,
        '而-2145320928为2004专用
        Case -2147467259, -2145320928
            Err.Clear
            Resume Exit_Here
        '其它情况,一律退出
        Case Else
            Err.Clear
            Resume Exit_Here
    End Select
End Sub
GMT+8, 2025-5-9 10:44 , Processed in 0.159258 second(s), 23 queries , Gzip On.
