查看: 1885|回复: 0
[求助]这个通过消息的方式加载定制菜单的程序问题出在哪里?
发表于 2002-7-27 20:15:00 | 显示全部楼层 |阅读模式
我按照《AutoCAD 2000 ARX 开发技术》第八章的程序,通过消息的方式
向AutoCAD发送字符串命令,实现启动AutoCAD 2000并加载定制菜单,源
程序如下:
// StartACAD.cpp : Defines the entry point for the application.
#include "stdafx.h"
//函数声明
void sendCommandToAutoCAD(const HWND hWndApp,
                    const HWND hWndAcad,const LPSTR cmd);
int APIENTRY WinMain(HINSTANCE hInstance,
                     HINSTANCE hPrevInstance,
                     LPSTR     lpCmdLine,
                     int       nCmdShow)
        // TODO: Place code here.
        //下述代码创建并注册应用程序窗口类
        char ClassName[]="Start AutoCAD";
        WNDCLASS WndClass;
        HWND hWndACAD=NULL;
        if(!hPrevInstance)
                memset(&WndClass,0x00,sizeof(WNDCLASS));
                WndClass.style=0;
                WndClass.lpfnWndProc=(WNDPROC)NULL; //不需要窗口回调函数
                WndClass.cbClsExtra=0;
                WndClass.cbWndExtra=0;
                WndClass.hInstance=hInstance;
                WndClass.hIcon=NULL;
                WndClass.hCursor=NULL;
                WndClass.hbrBackground=NULL;
                WndClass.lpszMenuName=NULL;
                WndClass.lpszClassName=ClassName;
                RegisterClass(&WndClass);
        //产生应用程序窗口,并返回句柄
        HWND hWndApp=CreateWindow(ClassName,"",WS_OVERLAPPEDWINDOW,
                          CW_USEDEFAULT,CW_USEDEFAULT,CW_USEDEFAULT,
                          CW_USEDEFAULT,NULL,NULL,hInstance,NULL);
        hWndACAD=FindWindow(NULL,"AutoCAD 2000");
        if(hWndACAD)
                BringWindowToTop(hWndACAD);
                ShowWindow(hWndACAD,SW_RESTORE);
        else
        //启动AutoCAD 2000并获得其主程序窗口
        if(WinExec("C:\\Program Files\\ACAD2000\\ACAD.exe",SW_SHOWNORMAL)<32)
                MessageBox(NULL,"AutoCAD 2000启动失败","Message",MB_OK);
                        return FALSE;
        for(int num=0;num<=100;num++)
                Sleep(500); //暂停,释放控制权
                if((hWndACAD=FindWindow(NULL,"AutoCAD 2000"))!=NULL)
                                break;
        char cmdString[133];  //命令字符串变量
        //设置系统变量FILEDIA
        strcpy(cmdString,"(setq IsChanged 1)(if(=(getvar\"FILEDIA\")1)(setvar\"FILEDIA\"0)(setq IsChanged 0))\n");
        sendCommandToAutoCAD(hWndApp,hWndACAD,cmdString);
        //加载定制菜单
        strcpy(cmdString,"MENU\nD:\\Sample.mnc\n");
        //恢复系统变量FILEDIA
        strcpy(cmdString,"(if(=IsChanged 1)(setvar\"FILEDIA\"1))\n");
        DestroyWindow(hWndApp);
        return 0;
//该函数向AutoCAD 2000主程序发送字符串命令
        if(!hWndAcad)
                return;
        COPYDATASTRUCT cmdMsg;
        cmdMsg.dwData=(DWORD)1;
        cmdMsg.cbData=(DWORD)strlen(cmd)+1;
        cmdMsg.lpData=cmd;
        SendMessageA(hWndAcad,WM_COPYDATA,(WPARAM)hWndApp,(LPARAM)&cmdMsg);
但我运行StartAcad.exe程序后,只启动了cad系统,并未能加载定制菜单(菜单
文件Sample.mnc放在目录D:\下)。下面是cad启动时命令行的显示结果:
Regenerating model.
(setq IsChanged 1)(if(=(getvar"FILEDIA")1)(setvar"FILEDIA"0)(setq IsChanged 0))
0
MENU
D:\Sample.mnc
(if(=IsChanged 1)(setvar"FILEDIA"1))
; error: no function definition: =ISCHANGED
AutoCAD menu utilities loaded.
我不知道问题出在哪里,请大家帮我看看!!!
我想用这种方法实现启动cad时自动运行一脚本语言程序,不知行否?
GMT+8, 2025-5-22 15:27 , Processed in 0.178328 second(s), 23 queries , Gzip On.
