查看: 1994|回复: 1
Add3DFace的问题?
发表于 2004-1-15 22:31:00 | 显示全部楼层 |阅读模式
Add3DFace(Point1, Point2, Point3[, Point4]) 说明第四点是可以忽略的,但例子出错?!何解?
  1. Sub Example_Add3DFace()
  2.     ' This example creates a 3D face in model space.
  3.     Dim faceObj As Acad3DFace
  4.     Dim point1(0 To 2) As Double
  5.     Dim point2(0 To 2) As Double
  6.     Dim point3(0 To 2) As Double
  7.   '  Dim point4(0 To 2) As Double
  8.
  9.     ' Define the four coordinates of the face
  10.     point1(0) = 0#: point1(1) = 0#: point1(2) = 0#
  11.     point2(0) = 5#: point2(1) = 0#: point2(2) = 1#
  12.     point3(0) = 1#: point3(1) = 10#: point3(2) = 0#
  13. '   point4(0) = 5#: point4(1) = 5#: point4(2) = 1#
  14.
  15.     ' Create the 3DFace object in model space
  16.     Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3) ', point4)
  17.     ZoomAll
  18.
  19. End Sub
发表于 2004-1-16 13:03:00 | 显示全部楼层
应该是帮助文件的错误。
在对象浏览器中是这样的:
Function Add3DFace(Point1, Point2, point3, Point4) As Acad3DFace
GMT+8, 2025-5-25 08:25 , Processed in 0.147207 second(s), 23 queries , Gzip On.
