查看: 1932|回复: 2
(图)特殊尺寸标注,LISP能否实现,请斑竹和高手看看
发表于 2004-1-18 22:20:00 | 显示全部楼层 |阅读模式
ACAD中的尺寸标注线看起来似乎必须与尺寸界线垂直,能否成120度呢?此尺寸标注在三维空视图时要用到,可是怎么能用LISP实现呢?图中尺寸标注线要与被标注的线平行,尺寸界线与被标注的线成120度夹角,请斑竹和LISP高手们看看能否用LISP实现此类尺寸标注!(具体见图)
发表于 2004-1-19 08:47:00 | 显示全部楼层
[原創]軸測圖標注程序
看過來. 這里有個合你用呀. 呵呵.
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=14589
;程序功能: 軸測圖標注.
;The program make by  BDYCAD
;本程序寫於2003-03-08
;程序更新日期:2004-01-19
(defun c:gT (/ os d date one tow three rotate-angle)
  (command "dimaligned" PAUSE PAUSE PAUSE)
  (setq os (getvar "osmode" ))(setvar "cmdecho" 0)(setvar "osmode" 0)
  (setq d (entlast))
  (setq date (entget d))
  (setq one (cdr(assoc 13 date)))
  (setq tow (cdr(assoc 14 date)))
  (setq three (cdr(assoc 10 date)))
  (setq rotate-anngle(angtos(angle one tow)))
  (if (or (= rotate-anngle "210") (= rotate-anngle "30"))
      (if(>(cadr three)(cadr tow))
        (command "dimedit" "o" d "" "90" "")
        (command "dimedit" "o" d "" "-30" ""))))
  (if (or (= rotate-anngle "330") (= rotate-anngle "150"))
        (command "dimedit" "o" d "" "30" ""))))
  (if (or (= rotate-anngle "270") (= rotate-anngle "90"))
      (if(>(car three)(car one))
  (setvar "cmdecho" 1)(setvar "osmode" os)
  (princ))
 楼主| 发表于 2004-1-19 17:01:00 | 显示全部楼层
太谢谢BDYCAD了,真是高手!向您学习!向您致敬!
GMT+8, 2025-5-14 08:27 , Processed in 0.168433 second(s), 26 queries , Gzip On.
