- 积分
- 15346
- 明经币
- 个
- 注册时间
- 2002-2-4
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2002-8-2 08:27:00
显示全部楼层
用lisp编程隐藏实体和显示实体如內,但用visual lisp编程的就沒有了!!!
;;; BLANK.LSP Version 1.0
;;; Copyright (C) 1995 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software and its
;;; documentation for any purpose and without fee is hereby granted.
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY.
;;; ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF
;;; MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;; BLANK, UNBLANK, and UNBLANKALL
;;; This module provides functions to manipulate the visibility field of
;;; AutoCAD objects. BLANK will make a selection set of objects invisible.
;;; UNBLANK will make a specified object (given its handle) visible.
;;; UNBLANKALL will make all blanked entities visible.
;;; Internal error handling.
(defun blank_error(s)
;; The strings in the following statements can be translated.
(if (/= s ;|MSG1|;"Function cancelled")
(princ (strcat ;|MSG2|;"\nBLANK Error: " s))
(setq *error* olderr)
(defun unblank_error(s)
(if (/= s ;|MSG3|;"Function cancelled")
(princ (strcat ;|MSG3|;"\nUNBLANK Error: " s))
(defun blank60 (e / e2)
(if (not (null (assoc '60 e)))
(setq e2 (subst '(60 . 1) '(60 . 0) e))
(setq e2 (append e '((60 . 1))))
(defun show60 (e / e2)
(setq e2 (subst '(60 . 0) '(60 . 1) e))
(setq e2 (append e '((60 . 0))))
(defun setvis ( vis ename / e)
(setq e (entget ename))
(if (eq vis 0)
(entmod (show60 e))
(entmod (blank60 e))
(entupd ename)
;; Blank vertices of polyline, if necessary
(if (eq (cdr (nth 1 e)) " OLYLINE")
(setq ename (entnext ename))
(while (eq (cdr (nth 1 e)) "VERTEX")
(if (eq vis 0)
(entmod (show60 e))
(entupd ename)
) ; while
) ; progn
) ; if polyline
(if (and (eq (cdr (nth 1 e)) "INSERT")
(assoc '66 e))
(while (eq (cdr (nth 1 e)) "ATTRIB")
(if (eq vis 0)
(entmod (show60 e))
(entupd ename)
) ; while
) ; progn
(defun c:blank ( ) ;;; / olderr echo ss i ename )
(setq olderr *error* ; Redefine error handler.
echo (getvar ;|MSG0|;"cmdecho")
*error* blank_error)
(setvar ;|MSG0|;"cmdecho" 0) ; Turn off cmdecho sysvar
(command ;|MSG0|;"_.undo" ;|MSG0|;"_group")
(setq ss (ssget))
(setq i 0)
(while (< i (sslength ss)) (progn
(setq ename (ssname ss i))
(setvis 1 ename)
(setq i (1+ i))
(setq *error* old_error) ; restore error function
(command ;|MSG0|;"_.undo" ;|MSG0|;"_end")
(setvar ;|MSG0|;"cmdecho" echo) ; restore cmdecho sysvar
(princ) ; Quiet exit.
(defun c:unblankall ( ) ;;; / olderr echo ss i ename )
*error* unblank_error)
;; Select all blanked entities
(setq ss (ssget ;|MSG0|;"_x" '((60 . 1))))
(if (not (null ss))
(setq i 0)
(princ (sslength ss))
(princ " blanked entities found.\n");
;; Unblank each entity in the set
(setvis 0 ename)
(setq i (1+ i))
(princ "\n0 blanked entities found.\n");
(defun c:unblank ( ) ;;; / olderr echo ss i ename hand )
(setq hand (getstring ;|MSG5|;"\nEnter handle of entity to be unblanked: "))
;; Unblank the entity if handle is not an empty string
(if (> (strlen hand) 0)
(setq ename (handent hand))
(if (/= nil ename)
(setvis 0 ename)
(princ ;|MSG6|;"Invalid handle.")
(princ) |
