查看: 1470|回复: 2
[求助]请问过滤选择时报错是怎么回事?
发表于 2004-2-8 22:20:00 | 显示全部楼层 |阅读模式
请教各位,报错信息为'-2147024809(80070057)',程序代码如下: Dim selset As AcadSelectionSet Set selset = ThisDrawing.SelectionSets.Add("jihe")
filtertype = 0 filterdata = "Text"
selset.SelectOnScreen filtertype, filterdata
MsgBox ok
For Each entry In selset
Next entry selset.Delete
发表于 2004-2-9 10:23:00 | 显示全部楼层
filtertype ,filterdata 必须为数组
  1. Sub kkk()
  2. Dim selset As AcadSelectionSet
  3. On Error Resume Next
  4. Set selset = ThisDrawing.SelectionSets("jihe")
  5. If Err Then Set selset = ThisDrawing.SelectionSets.Add("jihe")
  6. selset.Clear
  7. Dim filtertype(0 To 0) As Integer
  8. Dim filterdata(0 To 0) As Variant
  9. filtertype(0) = 0filterdata(0) = "Text"
  10. selset.SelectOnScreen filtertype, filterdata
  11. MsgBox selset.Count
  12. End Sub
 楼主| 发表于 2004-2-9 21:25:00 | 显示全部楼层
了解了!谢谢!
GMT+8, 2025-9-2 04:25 , Processed in 0.176119 second(s), 23 queries , Gzip On.
