查看: 1942|回复: 4
[求助]如何查看现有的图层是否被锁定?
发表于 2004-2-11 08:48:00 | 显示全部楼层 |阅读模式
如何查看现有的图层是否被锁定,也就是LAYER的群码
发表于 2004-2-11 09:11:00 | 显示全部楼层
(tblsearch "layer" "0");0是层名
发表于 2004-2-11 11:20:00 | 显示全部楼层
Command: (tblsearch "layer" "30")
((0 . "LAYER") (2 . "30") (70 . 1) (62 . 1) (6 . "CONTINUOUS"))
发表于 2004-2-11 11:58:00 | 显示全部楼层
得到Locked图层列表
(vl-load-com) (setq *acad-object* nil) ; Initialize global variable
(defun vlex-AcadObject ()
(cond (*acad-object*) ; Return the cached object
(T
(setq *acad-object* (vlax-Get-Acad-Object))
) (setq *vlex-ActiveDocument* nil)
(defun vlex-ActiveDocument ()
(cond (*vlex-ActiveDocument*) ; Return the cached object
(T
(setq *vlex-ActiveDocument* (vla-Get-ActiveDocument (vlex-AcadObject)))
) (defun vlex-LayerTable()
(vla-get-Layers (vlex-ActiveDocument))
) (defun vlex-ListLayers-Locked ( / each out)
(vlax-for each (vlex-LayerTable)
(if (= (vlax-get-property each "Lock") :vlax-true)
(setq out (cons (vla-get-name each) out))
out
) _$ Command: (vlex-ListLayers-Locked)
发表于 2004-2-11 20:28:00 | 显示全部楼层
  1. (defun lal (/ k las)
  2.    (while (setq la (tblnext "layer" (if k nil (setq k 1))))
  3.        (if (=   (cdr(assoc 70 la)) 4)
  4.          (setq las (append   (list(cdr (assoc 2 la))) las))
  5.        )
  6.    )las
  7. )
GMT+8, 2025-5-14 04:52 , Processed in 0.152265 second(s), 25 queries , Gzip On.
