查看: 2458|回复: 3
如何发布我的VBA程序?!
发表于 2004-2-11 16:07:00 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-2-11 16:25:00 | 显示全部楼层
这个我也做过,我自己写了一个宏。让cad启动时自动运行这个宏。有更好的方法,希望各位高手指点指点。
  1.   Sub InitializtionCAD()
  2.    On Error Resume Next
  3.    ThisDrawing.Utility.Prompt vbCrLf & "载入菜单同时在AutoCAD中显示"
  4.    ThisDrawing.Utility.Prompt vbCrLf & "加入CAD支持路径 "
  5.    ThisDrawing.Utility.Prompt vbCrLf & "--高武 2003年3月"
  6.
  7.
  8.        '增加支持路径
  9.        Dim preferences As AcadPreferences
  10.        Dim currSupportPath As String '支持目录
  11.        Dim supportFolder(0 To 10) As String
  12.
  13.        supportFolder(0) = Application.Path & "\图库"
  14.        supportFolder(1) = Application.Path & "\属性"
  15.        supportFolder(2) = Application.Path & "\图框"
  16.        supportFolder(3) = Application.Path & "\图标BMP"
  17.        supportFolder(4) = Application.Path & "\尺寸标注式样"
  18.        supportFolder(5) = Application.Path & "\菜单文件"
  19.        supportFolder(6) = Application.Path & "\Support"
  20.        supportFolder(7) = Application.Path & "\Help"
  21.        supportFolder(8) = Application.Path & "\Express"
  22.        supportFolder(9) = Application.Path & "\Fonts"
  23.        supportFolder(10) = Application.Path & "\GaoWuCad2004"
  24.
  25.        Set preferences = ThisDrawing.Application.preferences
  26.
  27.        currSupportPath = preferences.Files.SupportPath
  28.        For i = 0 To 10
  29.            If InStr(1, currSupportPath, supportFolder(i), 1) = 0 Then
  30.                currSupportPath = currSupportPath & ";" & supportFolder(i)
  31.            End If
  32.        Next i
  33.        preferences.Files.SupportPath = currSupportPath
  34.        Set preferences = Nothing
  35.
  36.        '改变打印样式搜索路径
  37.        ThisDrawing.Application.preferences.Files.PrinterStyleSheetPath = _
  38.        Application.Path & "\Plot Styles"
  39.        '改变打印机说明文字搜索路径
  40.        ThisDrawing.Application.preferences.Files.PrinterDescPath = _
  41.        Application.Path & "\Plotters\PMP Files"
  42.        '改变打印机配置搜索路径
  43.        ThisDrawing.Application.preferences.Files.PrinterConfigPath = _
  44.        Application.Path & "\Plotters"
  45.
  46.    Err.Clear
  47.    Application.MenuGroups.Load ("定制菜单GaoWu.mns")
  48.    If Err Then
  49.    Else:
  50.        Application.MenuGroups("快捷命令").Menus.InsertMenuInMenuBar "快捷命令", 10
  51.    End If
  52.    Err.Clear
  53.
  54. nd Sub
发表于 2004-2-11 17:56:00 | 显示全部楼层
好程序!!
发表于 2004-2-11 18:54:00 | 显示全部楼层
我也要,谢谢
GMT+8, 2025-11-30 04:20 , Processed in 0.144096 second(s), 23 queries , Gzip On.
