查看: 2453|回复: 2
图层问题
发表于 2002-8-3 22:38:00 | 显示全部楼层 |阅读模式
请教如何用autolisp获取cad图形文件中所有的图层名称?
   谢谢!
发表于 2002-8-5 09:15:00 | 显示全部楼层
程序如下...
(Defun C:SLayer ()
       (SetQ snl '()
             sll (TblNext "LAYER" T)
       (While (SetQ snl (Cons (Cdr (Assoc 2 sll)) snl)
                    sll (TblNext "LAYER" nil)
       (PrinC "\n现有层:")(PrinC snl)(PrinC)
发表于 2002-8-5 09:16:00 | 显示全部楼层
这样…
;;;USAGE: (TABLE_LIST "LAYER")
(defun TABLE_LIST (NAME / TBL TBL_LIST)
  (while (setq TBL (tblnext NAME (null TBL)))
    (setq TBL_LIST (cons (cdr (assoc 2 TBL)) TBL_LIST))
GMT+8, 2025-8-10 04:20 , Processed in 0.166213 second(s), 25 queries , Gzip On.
