查看: 1629|回复: 3
如何从固定点到当前鼠标的位置画一条多段线
发表于 2004-2-23 11:54:00 | 显示全部楼层 |阅读模式
请教各位大哥,如何从一个固定点到当前的鼠标的位置画一条多段线?谢谢指教!
 楼主| 发表于 2004-2-23 12:02:00 | 显示全部楼层
如果要画一条从固定点到当前鼠标位置的多段线,并且让它随着鼠标的移动而变化,该怎磨办?
发表于 2004-2-23 12:27:00 | 显示全部楼层
Sub ll()
Dim p1(0 To 2) As Double
Dim p2 As Variant
Dim pntobj As Variant Dim lobj As AcadLine p1(0) = 100
p1(1) = 100
p1(2) = 0 p2 = ThisDrawing.Utility.GetPoint(p1, "p2") Set lobj = ThisDrawing.ModelSpace.AddLine(p1, p2) End Sub
发表于 2004-2-23 12:30:00 | 显示全部楼层
呵呵,没看清楚,上面那个是直线,这个才是多段线 Sub ll()
Dim p2 As Variant
Dim pntobj As Variant Dim lobj As AcadLWPolyline
Dim vers(0 To 3) As Double 'p1(0) = 100
'p1(1) = 100
'p1(2) = 0 p2 = ThisDrawing.Utility.GetPoint(p1, "p2") vers(0) = 100
vers(1) = 100
vers(2) = p2(0)
vers(3) = p2(1) Set lobj = ThisDrawing.ModelSpace.AddLightWeightPolyline(vers) End Sub
GMT+8, 2025-11-30 04:15 , Processed in 0.159702 second(s), 24 queries , Gzip On.
