查看: 7362|回复: 21
[已解答] 框选统计圆数量程序改善
发表于 2015-6-2 15:39:43 | 显示全部楼层 |阅读模式
(defun c:S88 (/)
  (setq st (car (entsel)))
  (if (/= st nil)
    (progn (setq a1 (entget st)
                 a2 (cdr (assoc 40 a1))
                 a3 (cdr (assoc 8 a1))
                 a4 (ssget "x" (list (cons 8 a3)(cons 40 a2)))
                 a5 (sslength a4)
                 a2 (* a2 2)
                 a2 (rtos a2)
                 a5 (itoa a5)
  (alert  (strcat "\n直径【"a2"】 共计:【"a5"】个"))
以上程序只能单选统计圆的个数,如何修改才能实现框选各种圆对象并统计各种圆的个数,请高手指点迷津谢谢
发表于 2020-11-28 14:43:11 | 显示全部楼层
(defun c:YGS (/ AS D DD DNS FS GET GV K KS LEN NN S ST)
  (princ "\n功能 [统计圆直径数量弹窗]")
  (setq gv (getvar "dimzin"))
  (setvar 'dimzin 8)
  (if (setq get (ssget '((0 . "CIRCLE"))))
      (setq Len (sslength get) k 1)
      (repeat Len
  (setq nn (ssname get (setq Len (1- Len)))
        as (cdr (assoc 40 (entget nn)))
  as (atof (rtos as 2 2))
  (if (null (setq dd (assoc as Dns)))
    (setq Dns (cons (list as k) Dns))
    (setq Dns (subst (list as (1+ (cadr dd))) (assoc as Dns) Dns))
      (foreach x Dns
  (setq d   (car x)
        s   (cadr x)
        st (strcat "直径"
       (rtos (* d 2) 2 2)
       ",数量"
       (rtos s 2 2)
       "\n"
        ks (cons (list st) ks)
      (setq fs (apply 'strcat (mapcar 'car ks)))
      ;(alert fs)
(setq po (getpoint "input point----:"))
(command "text" po "2" "" FS"")
;(setq wz1 (entlast))
;(command "DDEDIT" wz1 "" "")
  (setvar 'dimzin gv)
回复 支持 1 反对 1
发表于 2015-6-2 17:17:02 | 显示全部楼层
  1. (defun c:tt (/ AS D DD DNS FS GET GV K KS LEN NN S ST)
  2.   (princ "\n功能 [统计圆直径数量弹窗]")
  3.   (setq gv (getvar "dimzin"))
  4.   (setvar 'dimzin 8)
  5.   (if (setq get (ssget '((0 . "CIRCLE"))))
  6.     (progn
  7.       (setq Len (sslength get) k 1)
  8.       (repeat Len
  9.   (setq nn (ssname get (setq Len (1- Len)))
  10.         as (cdr (assoc 40 (entget nn)))
  11.   as (atof (rtos as 2 2))
  12.   )
  13.   (if (null (setq dd (assoc as Dns)))
  14.     (setq Dns (cons (list as k) Dns))
  15.     (setq Dns (subst (list as (1+ (cadr dd))) (assoc as Dns) Dns))
  16.   )
  17.       )
  18.       (foreach x Dns
  19.   (setq d   (car x)
  20.         s   (cadr x)
  21.         st (strcat "直径"
  22.        (rtos (* d 2) 2 2)
  23.        ",数量"
  24.        (rtos s 2 2)
  25.        "\n"
  26.      )
  27.         ks (cons (list st) ks)
  28.   )
  29.       )
  30.       (setq fs (apply 'strcat (mapcar 'car ks)))
  31.       (alert fs)
  32.     )
  33.   )
  34.   (setvar 'dimzin gv)
  35.   (princ)
  36. )
牛  发表于 2015-6-30 08:00
 楼主| 发表于 2015-6-2 18:49:46 | 显示全部楼层
琴剑江山_10184 发表于 2015-6-2 17:17
谢谢您的修改
 楼主| 发表于 2015-6-3 08:21:04 | 显示全部楼层
通过测试文档结果显示为如上图,显示的是没有汇总。
发表于 2015-6-3 14:01:30 | 显示全部楼层
小数点的问题,上面代码已更新
发表于 2015-6-18 16:47:43 | 显示全部楼层
与燕秀有得一比!
发表于 2017-7-28 22:58:43 | 显示全部楼层
谢谢各位,辛苦了
发表于 2017-8-21 21:58:55 | 显示全部楼层
若可以把得到之信息轉出,或可讀取就更完美了....謝謝
GMT+8, 2025-4-23 05:57 , Processed in 0.271371 second(s), 38 queries , Gzip On.
