查看: 1342|回复: 5
[提问] 请教打包进vlx文件中txt路径问题
发表于 2015-6-15 20:32:35 | 显示全部楼层 |阅读模式
用这些代码生成vlx文件总是"无法加载文档".
请教大神如何解决?谢谢!
(defun read_txt (/ txt opt_1 fn fp)
  (if (= (getvar "filedia") 0)
    (setvar "filedia" 1)
  (setq fn (findfile "flsj.txt"))
  (if (= fn nil)
    (progn (alert "无法加载文档!") (exit))
  (setq fp (open fn "r"))
  (setq txt_sb '())
  (setq opt_1 1)
  (while (= opt_1 1)
    (setq txt (read-line fp))
    (if (/= txt nil)
(setq txt_sb1 (read txt))
(setq txt_sb (append txt_sb (list txt_sb1)))
      (setq opt_1 0)
  (close fp)
发表于 2015-6-15 21:07:06 | 显示全部楼层
flsj.txt文件没有打包进vlx里面吧
 楼主| 发表于 2015-6-15 21:56:21 | 显示全部楼层
打包了,就是提示错误.
发表于 2015-6-15 22:22:44 来自手机 | 显示全部楼层
text打包了要用v|-resource
求用法!!谢谢!!  发表于 2015-6-16 12:53
发表于 2015-6-16 17:47:51 | 显示全部楼层
发表于 2022-5-13 08:28:15 来自手机 | 显示全部楼层
没有看懂黄大师这个帖子,也没有v|-resource函数啊
GMT+8, 2025-5-15 20:13 , Processed in 0.147971 second(s), 26 queries , Gzip On.
