- 积分
- 3555
- 明经币
- 个
- 注册时间
- 2015-6-14
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
冲压模具设计,跪求一个画图带属性的lisp,或者外挂:因本人之前在FOX,用的冲模一厂的FOXPRESS-2012,里面的图元都不是块但是都带有属性的。今年辞职,在小厂做,没外挂,冲压模具结构图都是自己一个一个画的,也无法自动拆图,最主演是画的图形没属性,老是加工厂问,跪求大家给发个能定义图元加工属性的外挂,下面是我用的打开图层的代码:图层指令(defun c:N()
(command "layer" "T" "*" "on" "*" ""))
(defun c:OP3()
(command "layer" "S" "HH" "OFF" "*" "N" ""))
(defun c:OP4()
(command "layer" "S" "BP" "OFF" "*" "N" ""))
(defun c:OP5()
(command "layer" "S" "PP" "OFF" "*" "N" ""))
(defun c:OP6()
(command "layer" "S" "PPLEAD" "OFF" "*" "N" ""))
(defun c:OS1()
(command "layer" "S" "SP" "OFF" "*" "N" ""))
(defun c:OS2()
(command "layer" "S" "SB" "OFF" "*" "N" ""))
(defun c:P5B()
(command "layer" "S" "UD" "OFF" "*" "N" ""))
(defun c:OD5()
(command "layer" "S" "DB" "OFF" "*" "N" ""))
(defun c:OD4()
(command "layer" "S" "CB" "OFF" "*" "N" ""))
(defun c:OD3()
(command "layer" "S" "DD" "OFF" "*" "N" ""))
(defun c:OD2()
(command "layer" "S" "CC" "OFF" "*" "N" ""))
(defun c:OD1()
(command "layer" "S" "DH" "OFF" "*" "N" ""))
(defun c:OP()
(defun c:OS4()
(command "layer" "S" "SPLEAD" "OFF" "*" "N" ""))
(defun c:OD()
(command "layer" "S" "DBLEAD" "OFF" "*" "N" ""))
(defun c:TP3()
(command "layer" "T" "HH" "S" "HH" ""))
(defun c:TP4()
(command "layer" "T" "BP" "S" "BP" ""))
(defun c:TP5()
(command "layer" "T" "PP" "S" "PP" ""))
(defun c:TS1()
(command "layer" "T" "SP" "S" "SP" ""))
(defun c:TS2()
(command "layer" "T" "SB" "S" "SB" ""))
(defun c:TS4()
(command "layer" "T" "SPLEAD" "S" "SPLEAD" ""))
(defun c:TP5B()
(command "layer" "T" "UD" "S" "UD" ""))
(defun c:TD5()
(command "layer" "T" "DB" "S" "DB" ""))
(defun c:TD4()
(command "layer" "T" "CB" "S" "CB" ""))
(defun c:TD3()
(command "layer" "T" "DD" "S" "DD" ""))
(defun c:TD2()
(command "layer" "T" "CC" "S" "CC" ""))
(defun c:TD1()
(command "layer" "T" "DH" "S" "DH" ""))
(defun c:TP()
(command "layer" "T" "PPLEDA" "S" "PPLEAD" ""))
(defun c:TD()
(command "layer" "T" "DDBLEAD" "S" "DBLEAD" ""))
(defun c:O2()
(command "layer" "S" "MATER" "OFF" "*" "N" ""))
(defun c:OUB()
(command "layer" "T" "*" "OFF" "*" "Y" "" "")
(command "layer" "on" "HP,UE,BB,BP,PP,PPLEAD,SB,SP,SPLEAD,UD" ""))
(defun c:ODB()
(command "layer" "on" "DH,DE,CC,DD,CB,DB,OB,OP,DBLEAD,CBLEAD" ""))
(defun c:T2()
(command "layer" "T" "MATER" "S" "MATER" ""))
(defun c:ZE()
(COMMAND "ZOOM" "A" "" ))
(defun c:ODM()
(command "layer" "S" "DIM" "OFF" "*" "N" ""))
(defun c:TDM()
(command "layer" "T" "DIM" "S" "DIM" ""))
(defun c:T0()
(command "layer" "T" "0" "S" "0" ""))
(defun c:O0()
(command "layer" "S" "0" "OFF" "*" "N" ""))
(defun c:1 ()
(command "dimlinear")
(defun c:2 ()
(command "dimaligned")
(defun c:4 ()
(command "dimradius")
(defun c:5 ()
(command "dimdiameter")
(defun c:6 ()
(command "dimangular")
(defun c:8 ()
(command "dimordinate")
(defun c:9 ()
(command "QLEADER")
请各位不吝赐教,跪谢大家了.
