ljpnb 发表于 2015-6-27 23:25
修改过了,能运行,点取消还会执行命令,没搞明白。。。  - (defun dcl_dxz ()
- (if (> (setq dcl_id (load_dialog "dxz")) 0) (progn
- (if (new_dialog "dxz1" dcl_id) (progn
- ;;设置默认值
- (set_tile "dia_out" "108")
- (set_tile "dia_thi" "4.5")
- (set_tile "dia_in"
- (rtos (- (atof (get_tile "dia_out"))
- (* 2 (atof (get_tile "dia_thi")))
- (set_tile "dia_dn" "100")
- (set_tile "dxz_angi" "8")
- (set_tile "dxz_ango" "8")
- (set_tile "dxz_len" "200")
- (set_tile "dxz_rad"
- (rtos (* 1.5 (atof (get_tile "dia_out"))))
- (set_tile "dxz_depi" "5")
- (set_tile "dxz_depo" "5")
- (action_tile "draw" "(done_dialog 1)")
- (action_tile "cancel" "(done_dialog 0)")
- ;;(setq dd (start_dialog))
- (setq diameter_mm (atof (get_tile "dia_out")))
- (setq thickness_mm (atof (get_tile "dia_thi")))
- (setq angle_entry (d2r (atof (get_tile "dxz_angi"))))
- (setq angle_exit (d2r (atof (get_tile "dxz_ango"))))
- (setq length_horizon (atof (get_tile "dxz_len")))
- (setq depth_horizon_entry (atof (get_tile "dxz_depi")))
- (setq depth_horizon_exit (atof (get_tile "dxz_depo")))
- (setq re (start_dialog))
- (princ "\n无法显示对话框!")
- (unload_dialog DCL_ID)
- (princ "\n无法加载对话框!")
- (if (= re 1) (ok_run) )
