只选择纵线 - (vl-load-com)
- (defun c:tt (/ ss lst lst1 m n x y f)
- (defun x_ssn (ss / n lst)
- (repeat (setq N (sslength ss))
- (setq LST (cons (ssname SS (setq N (1- N))) LST))
- (defun deldup (ptLst alw / pt1)
- (cond ((<= (length ptLst) 1) ptLst)
- (t
- (setq pt1 (car ptLst))
- (cons pt1
- (vl-remove-if
- '(lambda (x) (equal pt1 x alw))
- (deldup (cdr ptLst) alw)
- (defun get_dxf (en num /) (cdr (assoc num (entget en))))
- (setq f (open (getfiled "坐标输出为:" "d:/" "txt" 1) "w"))
- (prompt "\n仅选择纵向线:")
- (setq ss (ssget)
- lst (x_ssn ss)
- lst (vl-sort
- lst
- '(lambda (x y) (< (car (get_dxf x 10)) (car (get_dxf y 10))))
- (foreach n lst
- (setq ss (ssget "f" (list (get_dxf n 10) (get_dxf n 11))))
- (setq lst1 (x_ssn ss))
- (setq lst1 (deldup (vl-remove nil
- (mapcar '(lambda (x)
- (vlax-invoke
- (vlax-ename->vla-object n)
- 'IntersectWith
- (vlax-ename->vla-object x)
- acExtendNone
- lst1
- 1e-6
- lst1 (vl-sort lst1 '(lambda (x y) (< (cadr x) (cadr y))))
- (foreach m lst1
- (write-line
- (strcat (rtos (car m) 2 3) "," (rtos (cadr m) 2 3))
- f
- (write-line "下一个" f)
- (close f)
- (princ)
