查看: 1765|回复: 3
[已解答] 连续COPY 和 ROTATE
发表于 2015-7-12 10:10:05 | 显示全部楼层 |阅读模式
下面这段程序挺好用的,但有个缺陷:选择完要复制的实体,在打开“正交”时选择第2个点无效(第2点仅在<复制基点>的垂直和水平方向),在关闭“正交”时就正常了,可以选到任意点。
请大师们指点:怎么解决“打开正交”时也能选到任意点
;;;引自龙龙仔的代码
(defun C:CR1 (/ HOLDOSMODE SS SS1 PT1 PT2 ROT MARK)
  (arxload "ACETUTIL.ARX" NIL)
  (defun RTD (ANG) (* ANG (/ 180 pi)))
  (setq HOLDOSMODE (getvar "osmode"))
  (if (setq SS1 (ssget))
      (initget 1)
      (setq PT1 (getpoint "\n指定基准点: "))
      ;;acet-ss-drag-move缺点:
      ;;Normally returns the selected point, but will honor "initget"
      ;;settings and can return arbitrary text or keywords.
      ;;Returns nil if the dragging operation is aborted.
      (while (setq PT2 (acet-ss-drag-move
                         SS1
                         PT1
                         "\n指定位移的第二点: "
                         t
        (setvar "osmode" 0)
        (setq MARK (entlast))
        (command "_.copy" SS1 "" PT1 PT2)
        (setq SS (ssadd))
        (while (setq MARK (entnext MARK))
          (ssadd MARK SS)
        (setvar "osmode" HOLDOSMODE)
        (if (setq ROT (acet-ss-drag-rotate
                        SS
                        PT2
                        "\n指定旋转角度: "
                        t
          (setq ROT (RTD ROT))
          (setq ROT 0.0)
        (command "_.ROTATE" SS "" PT2 ROT)
该贴已经同步到 冒个烟圈的微博
发表于 2015-7-12 12:24:23 | 显示全部楼层
  1. ;; tt(连续COPY和ROTATE)
  2. (defun c:tt (/ ss1 p1 p2 ang s0 ss2)
  3.   (defun rtd (ang) (* ang (/ 180 pi)))
  4.   (if (and (setq ss1 (ssget))
  5.            (setq p1 (getpoint "\n指定基准点: "))
  6.       )
  7.     (while (setq p2 (getpoint p1 "\n指定位移的第二点: "))
  8.       (setq s0 (entlast))
  9.       (command "_.copy" ss1 "" "non" p1 "non" p2)
  10.       (setq ss2 (ssadd))
  11.       (while (setq s0 (entnext s0))
  12.         (ssadd s0 ss2)
  13.       )
  14.       (if (setq ang (getangle p2 "\n指定旋转角度: "))
  15.         (setq ang (rtd ang))
  16.         (setq ang 0.0)
  17.       )
  18.       (if (/= rpt 0)
  19.         (command "_.rotate" ss2 "" "non" p2 ang)
  20.       )
  21.     )
  22.   )
  23.   (princ)
  24. )
 楼主| 发表于 2015-7-12 13:13:17 | 显示全部楼层
xyp1964 发表于 2015-7-12 12:24
谢谢院长亲自出手
发表于 2019-7-9 14:04:01 | 显示全部楼层
刚好需要这个东西,收下了,感谢分享
用的过程中发现一个问题,貌似对块使用这个命令的时候,连续复制的块,前一个块会跟着后一个块的旋转角度,一起旋转
GMT+8, 2025-7-1 06:27 , Processed in 0.153009 second(s), 31 queries , Gzip On.
