查看: 874|回复: 9
[提问] 还是关于布局空间,请教大家
发表于 2015-7-14 20:24:49 | 显示全部楼层 |阅读模式
问题描述如下:已设置好一个布局,如何复制n个上述布局,并且将所有的布局的名称改掉?
发表于 2015-7-15 14:06:49 | 显示全部楼层
Command: layout
Enter layout option [Copy/Delete/New/Template/Rename/SAveas/Set/?] <set>: c
Enter name of layout to copy <Layout1>:
Enter layout name for copy <Layout1 (3)>: 新图1
Layout "Layout1" copied to "新图1".
 楼主| 发表于 2015-7-15 15:24:15 | 显示全部楼层
edata 发表于 2015-7-15 14:06
Command: layout
Enter layout option [Copy/Delete/New/Template/Rename/SAveas/Set/?] : c
Enter name  ...
用vlisp语言怎么实现?
发表于 2015-7-15 17:20:09 | 显示全部楼层
    (vl-cmdf "_.layout" "_copy" clayoutName tmpName)
    (vl-cmdf "_.layout" "_rename" clayoutName NLayoutName)
 楼主| 发表于 2015-7-15 17:50:33 | 显示全部楼层
    (vl-cmdf "_.layout" "_rename" clayoutNam ...
有没有更加高级的方法?
发表于 2015-7-15 18:31:17 | 显示全部楼层
高级的代码不止一行。
参见LEE-MAC的布局分图
  1. (defun c:layoutcutter ( / cnt doc idx lay lst new prf psp sel str tmp )
  2.     (setq prf "Layout"
  3.           psp (= 1 (getvar 'cvport))
  4.     )
  5.     (if (setq sel (ssget "_:L" (list (if psp (cons 410 (getvar 'ctab)) '(410 . "Model")))))
  6.         (progn
  7.             (setq doc (vla-get-activedocument (vlax-get-acad-object))
  8.                   lay (vla-get-activelayout doc)
  9.                   tmp (mapcar 'strcase (cons "model" (layoutlist)))
  10.                   cnt 0
  11.             )
  12.             (while (member (strcase (setq str (strcat prf (itoa (setq cnt (1+ cnt)))))) tmp))
  13.             (setq new (vla-add (vla-get-layouts doc) str))
  14.             (repeat (setq idx (sslength sel))
  15.                 (setq lst (cons (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst))
  16.             )
  17.             (vlax-invoke doc 'copyobjects
  18.                 (if psp (cons (vla-item (vla-get-block lay) 0) (reverse lst)) (reverse lst))
  19.                 (vla-get-block new)
  20.             )
  21.             (foreach obj lst (vla-delete obj))
  22.             (if psp
  23.                 (foreach prp
  24.                    '(
  25.                         PlotType
  26.                         PlotHidden
  27.                         PlotOrigin
  28.                         PlotRotation
  29.                         PlotViewportBorders
  30.                         PlotViewportsFirst
  31.                         PlotWithLineweights
  32.                         PlotWithPlotStyles
  33.                         ScaleLineweights
  34.                         ShowPlotStyles
  35.                         StandardScale
  36.                         StyleSheet
  37.                         UseStandardScale
  38.                         CanonicalMediaName
  39.                         CenterPlot
  40.                         ConfigName
  41.                         PaperUnits
  42.                     )
  43.                     (vl-catch-all-apply 'vlax-put-property (list new prp (vlax-get-property lay prp)))
  44.                 )
  45.             )
  46.         )
  47.     )
  48.     (princ)
  49. )
  50. (vl-load-com) (princ)
 楼主| 发表于 2015-7-15 18:45:29 | 显示全部楼层
edata 发表于 2015-7-15 18:31
高级的代码不止一行。
参见LEE-MAC的布局分图
膜拜,最近正在学习和布局有关的函数,发现这方面的资料好少呀!
 楼主| 发表于 2015-7-15 21:05:02 | 显示全部楼层
高级的代码不止一行。
参见LEE-MAC的布局分图
请教前辈,我发现,如果有几个布局的话,改掉中间的布局名称,对布局的实际顺序(在程序中的顺序)会产生影响,这个怎么解决?我希望它们还是我们看到的自左向右的顺序。
发表于 2015-7-16 10:34:00 | 显示全部楼层
那么你可以研究这个。
http://lee-mac.com/lisp/html/TabSortV2-2.html
发表于 2015-7-27 12:00:56 | 显示全部楼层
高级的代码不止一行。
参见LEE-MAC的布局分图
别人都称你e大,真不亏是e大
GMT+8, 2025-5-21 18:22 , Processed in 0.223232 second(s), 30 queries , Gzip On.
