查看: 798|回复: 2
[已解答] 如何在增量的同时,为生成的结果都加上一个单位呢
发表于 2015-7-17 10:05:14 | 显示全部楼层 |阅读模式
诚求帮助,谢谢
下面的源码的用途是:为选中内容批量增加一量值(但修改之后的数值都是没有单位的)
如何修改这个程序,使得生成的每个结果能包含后缀m
;本程序将指定数字增加一量值
(defun c:nnnn( / sset ct num ed ent temp temp1 value)
(princ "\nDecrease the value of selected text, Version 1.0, (c) 1999 by Z.L.Wang")
(prompt "\nSelect text to change: ")
(setq sset (ssget '((0 . "TEXT"))))
(if (null sset)
(princ "\nNothing selected.")
(exit)
(setq value (getreal "请输入增量: "))
(setq ct 0)
(setq num (sslength sset))
(repeat num
(setq ent (ssname sset ct))
(setq ed(entget ent))
(setq temp (assoc 1 ed))
(setq temp1 (atof (cdr temp)))
(setq temp1 (+ temp1 value))
(setq temp (rtos temp1 2 3))
(setq ed (subst (cons 1 temp) (assoc 1 ed) ed))
(entmod ed)
(setq ct (+ 1 ct))
发表于 2015-7-17 10:23:55 | 显示全部楼层
  1. (defun c:nnnn ( / sset ct ed temp value)
  2. (princ "\nDecrease the value of selected text, Version 1.0, (c) 1999 by Z.L.Wang")
  3. (prompt "\nSelect text to change: ")
  4. (if (and (setq sset (ssget '((0 . "TEXT"))))
  5.          (setq value (getreal "请输入增量: "))) (progn
  6.   (setq ct 0)
  7.   (repeat (sslength sset)
  8.     (setq ed (entget (ssname sset ct)))
  9.     (setq temp (atof (cdr (assoc 1 ed))))
  10.     (setq temp (strcat (rtos (+ temp value) 2 3) "m"))
  11.     (entmod (subst (cons 1 temp) (assoc 1 ed) ed))
  12.     (setq ct (1+ ct))
  13.   )
  14. )
  15.   (princ "\nNothing selected.")
  16. )
  17. )
qq284417238 + 1 很给力!
 楼主| 发表于 2015-7-17 10:29:01 | 显示全部楼层
ZZXXQQ 发表于 2015-7-17 10:23
谢谢帮忙,已经完美解决我的问题了。非常感谢
GMT+8, 2025-5-21 15:15 , Processed in 0.178102 second(s), 26 queries , Gzip On.
