查看: 1040|回复: 3
[经验] Alisp文字先创建后定位测试
发表于 2015-7-22 11:51:56 | 显示全部楼层 |阅读模式
  1. (defun c:gg(/ tent gr el l pt)
  2. (prompt "*********Alisp文字先创建后定位测试**********")
  3. ;先创建
  4. (setq tent (entmakex  '((0 . "text") (1 . "文字") (40 . 2) (10 0 0 0))))
  5. ;后定位
  6.   (while (and (setq gr (grread t 5 0))
  7.               (eq 5 (car gr))
  8.               )
  9.      (setq pt (cadr gr)
  10.            el (entget tent)
  11.            l (assoc 10 el)
  12.            el (subst (cons 10 pt) l el)
  13.            )
  14.      (entmod el)
  15.     )
  16. (princ)
  17. );end defun
发表于 2015-7-22 14:15:49 | 显示全部楼层
用这个函数(acet-ss-drag-move ss pt [prompt] [highlight [cursor]]),效果更好。
 楼主| 发表于 2016-4-20 23:12:58 | 显示全部楼层
  1. (defun c:gg(/ obj PT PT_OLD)
  2. (prompt "*********Vlisp文字先创建后定位测试**********")
  3. ;先创建
  4. (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
  5. (setq PT_OLD (vlax-3D-point '(0 0)))
  6. (setq obj (vla-addtext modelspace "文字" PT_OLD 2.25))
  7. ;后定位
  8.   (while (and (setq gr (grread t 5 0))
  9.               (eq 5 (car gr))
  10.               )
  11.      (setq PT (vlax-3D-point(cadr gr)))
  12.      (vla-Move obj PT_OLD PT)
  13.      (setq PT_OLD PT)
  14.     )
  15. (princ)
  16. )
 楼主| 发表于 2016-4-20 23:22:07 | 显示全部楼层
  1. (defun C:TT (/ obj PT PT_OLD TEST TMP)
  2.     (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
  3.     (setq PT_OLD (vlax-3D-point '(0 0)))
  4.     (setq obj (vla-addtext modelspace "文字" PT_OLD 2.25))
  5.     (princ "\n指定放置位置...")
  6.     (setq TEST t)
  7.     (while TEST
  8.           (setq TMP (grread t 7 1))
  9.           (cond
  10.                     ((= (car TMP) 3) ;_左键
  11.                (setq TEST NIL)
  12.               )
  13.               ((= (car TMP) 11) ;_右键
  14.                (vla-delete obj)
  15.                (setq TEST NIL)
  16.               )
  17.               ((= (car TMP) 5) ;_移动
  18.                (setq PT (vlax-3D-point(cadr TMP)))
  19.                (vla-Move obj PT_OLD PT)
  20.                (setq PT_OLD PT)
  21.               )
  22.            )
  23.    ) ;_结束 while
  24.   (princ)
  25. )
GMT+8, 2025-5-20 13:22 , Processed in 0.166917 second(s), 26 queries , Gzip On.
