查看: 1499|回复: 3
[已解答] 提取点的属性到txt或xls
发表于 2015-7-26 20:35:34 | 显示全部楼层 |阅读模式
30明经币
如图。需要算点的平均标高,
希望能框选全部或部分点,属性里面的数值能导出到txt或xls
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun c:tt()(vl-load-com) (setq lst (mapcar '(lambda (a) (mapcar '(lambda (att) (vl-princ-to-string (list (Vlax-safearray->list (Variant-value (Vla-get-insertionpoint att)))(vla-get-TextString att)))) (vlax-invoke (vlax-ename->vla-object a) "GetAttributes"))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "INSERT"))))))) ) (setq file ...
发表于 2015-7-26 20:35:35 | 显示全部楼层
  (setq lst
    (setq file (getfiled "文件保存为" "" "txt" 1))
    (if (findfile file)
    (setq ff (open file "a"))
    (setq ff (open file "w"))
  (mapcar '(lambda (a) (write-line (car a) ff)) lst)
  (close ff)
(prin1)
 楼主| 发表于 2015-7-26 20:39:18 | 显示全部楼层
求帮忙。谢谢大家了。。。。
 楼主| 发表于 2015-7-26 21:37:32 | 显示全部楼层
  (setq lst
非常感谢。
GMT+8, 2025-10-29 04:08 , Processed in 0.195626 second(s), 29 queries , Gzip On.
